Hi Panchal Maheshkumar, I send you the link so you can download the service manual of your Sony Bravia KDL46W950A
I hope you can solve the problem
Greetings Franco Dosil
Hola Panchal Maheshkumar, te envio el link para que puedas descargar el manual de servicio de tu Sony Bravia KDL46W950A
Espero puedas resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/sony_kdl-46w950_kdl-46w954_kdl-46w955_kdl-55w950a_kdl-55w954a_kdl-55w955a_kdl-55w957a_chassis_rb1g.pdf/download.html
SOURCE: sony bravia KDL40S2000 standby blink four times
A 4 flash issue means either the back light inverter (power supply) has failed or that one of the fluorescent tubes in the panel has failed. The only way to know for sure is to check the fuses that are on the inverter board. If one or more of the fuses are opne, then it is likely the inverter board is bad. If the fuses all check good, then the panel is at fault. If it is the inverter board, it is a part you could replace yourself; the cost of the board is about $70. If it is the panel, you would probably want to consider replacing the TV, as the repair costs would be over $1000
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
SOURCE: No picture or sound. Red light
Just a correction, it is not necessary that 4 times red light blinking always shows inverter board problem.
It depends on chassis/ model number of Sony bravia tv to what is error code of 4 blinks as it would be mentioned service manual.
I'm Sony tech and can help you, let me know model number written at back of tv to provide you exact info about 4 times red light blinking.
Thanks.
