Any way to reset after "protection circuitry" is tripped three times on RX-s602
    Top Expert:
  • Audio Player... Master
  • 10,535 Answers
Hi Jonny andreassen, for what you say, your Yamaha enters protection mode due to a malfunction in the output tepa
As JonSnell Electronic suggests, you should repair or have the power output stages repaired, you also have to control the connection cables and the loudspeakers, due to the possibility that some are damaged and can generate a fault in the Yamaha
I hope you can solve it
Greetings Franco Dosil
Hola Jonny andreassen, por lo que comentas, tu Yamaha entra en modo proteccion por un mal funcionamiento en la tepa de salida
Como te sugiere JonSnell Electronic, deberas reparar o hacer reparar las etapas de salida de potencia, tambien tienes que controlar los cables de conexion y los bafles, por la posibilidad que alguno se encuentre da?ado y pueda generar una falla en el Yamaha
Espero puedas resolverlo
Saludos Franco Dosil
Posted on Sep 30, 2019
    Top Expert:
  • 30,686 Answers
Yes, repair the amplifier fault and it will reset.
Testimonial: "has disconnected everything but nothing happened"
  • JonSnell Electronic
    JonSnell Electronic Sep 30, 2019
    The output stage in the amplifier has been damaged and must be repaired by a qualified service department.
  • jonny andreassen
    jonny andreassen Sep 30, 2019
    is there no button combination to reset
6ya staff
SOURCE:
Anonymous
  • 150 Answers
SOURCE: RX-V800 shuts off after 7 seconds turned it on, what should I do?
Can you post that diagram here? Or you can email it to me. I can't make any promises, But Im glad to help, I have done much board work in my time, and this one just sounds interesting. L8R
Posted on Sep 17, 2007
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: the power kicks off after being on for about three
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 13, 2010
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: my rx-v367 does not power
hi,
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong. Is there is any standby light. If not check the AC fuse.
Normally AV receivers show this when any of the output amplifier get some problem. there are five amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
First of all remove all speaker connections from the amplifier and powerup the amplifier. If the amplifier turns ON then, then any of the speaker have some problem.
If not You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Posted on Feb 17, 2011
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: how do you reset a
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
Posted on May 26, 2011
claudeinmo
Claude Kayser
  • 9098 Answers
SOURCE: How do I reset Yamaha rx-a4730 it won't turn on just blinks Manual says it is in circuitry protection mode
Yamaha RX-V650 won't power on - Service manual, repair and unlock ...
forum.eserviceinfo.com/viewtopic.php?t=59945
10 posts - ?6 authors Posted: Sat Aug 29, 2009 1:26 pm Post subject: Yamaha RX-V650 won't power on ... When i came back from a holliday, my receiver won't power up anymore. .... isn't powered (no voltage on the base) when the receiver doesn't comes on.
Posted on Sep 12, 2015
Yamaha rx-v679 only standby red power bottom when you turn on its only blinking what is the problem ?
It is most likely locked in protect mode. Try resetting by holding the TONE CONTROL and INFO buttons and pressing power. Watch the front panel display when you do this, and it will tell you what protect was tripped.
Jan 11, 2016 | Yamaha Audio Players & Recorders
Sep 16, 2007 | Yamaha RX-V800 Receiver
10 posts - ‎6 authors Posted: Sat Aug 29, 2009 1:26 pm Post subject: Yamaha RX-V650 won't power on ... When i came back from a holliday, my receiver won't power up anymore. .... isn't powered (no voltage on the base) when the receiver doesn't comes on.
Sep 12, 2015 | Yamaha Audio Players & Recorders
Any way to reset after "protection circuitry" is tripped three times on RX-V675?
Try pressing and holding the 'tone control' and 'info' buttons, then press power. This should unlock the protection lock. the lock is there so that the unit cannot be repeatedly turned on when there is a problem that could cause permanent damage to the circuitry.
How do I reset the protection circuitry on Yamaha RX-A820?
press and hold the 'tone control' and 'info' buttons and press power. This will release the protect. The first thing that show on the display will be the protect code to tell you why it shut down. If it turns right back off, then you most likely have a short in the amp that will need to be repaired.
Jan 25, 2015 | Yamaha Audio Players & Recorders
How to reset yamaha RX-1030 Amplifier
There is no reset, Sometimes if you hit them on the top or sides with your fist, They will start working again.
Aug 09, 2014 | Audio Players & Recorders
After power outage, the units internal saftey switch has activated. How do i reset the reciever? It's a Yamaha RX A1000
If the protection circuitry has been activated 3 times consecutively you may have to contact Yamaha as it says in the Troubleshooting section of the manual.
http://usa.yamaha.com/products/audio-visual/aventage/rx-a1000_black__u/
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Jul 27, 2011 | Yamaha RXA1000 Receiver
Rx-v795a reciever shuts off after 5 min or more can not hear fan in reciever for cooling.
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 15, 2010 | Yamaha RX-V795 Receiver
Just bought yamaha rx-v467 reciever, it worked for 2 mins then it trips out, wired all surround sound correctly. now unit only turns on for 2 secs then turns off. it does it 3 times and then you have to...
Nov 09, 2010 | Yamaha RX-V463 Receiver
Yamaha Receiver loses audio when changing DTV stations
I believe changing stations is triggering the protection on receiver. When you go to another input and back you give time for the protection circuitry to release speakers again. Try muting your receiver before changing channels. Good luck!
Nov 21, 2008 | Yamaha RX-V463 Receiver
47 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
