Konica Minolta Konica 512 42PL Logo
sagar thorwat Posted on Sep 30, 2019
Allwin konica 512 42pl error solution
40100f6 encoder error
Raj Multimedia Jmp
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 18, 2022
Raj Multimedia Jmp
Contributor
Level 1:
Answers
Questions
0
Helped
1198
Points
6
Dyhx a type board 80020001 error
prasad maddineni
Level 1:
  • Posted on Oct 25, 2019
prasad maddineni
Contributor
Level 1:
Answers
Questions
0
Helped
1198
Points
(40020001)Internal 1.
How do I resolve Error Code: 81: Run Until Line Is Empty? (Does it mean that there's something wrong with the encoder?)
When you're trying to encode a video and you get an error code that says "Run Until Line Is Empty," it can be frustrating because you have no idea what it means. In most cases, this code means that there's something wrong with the encoder. If you're getting this error code, it's best to try encoding the video on a different computer or using a different encoder.
Konica minolta 1050e error code SC23-13
Code
SC23-13
Description
Air separation motor (M10) rotation abnormality. Since an error is detected when the M10 turn ON, turn it OFF. An error is still detected when turn it ON again.
Causes
Air separation motor (M10) Air motor encoder sensor (PS30) Resetting of the intermediate toner hopper section
Remedy
The main body stops immediately to turn OFF the RL1 (main).
KONICA MINOLTA 1050e code SC23-13
2answers
Error code 23-13 konica minolta 1050
Toner conveyance abnormality SC23-13. Air separation motor (M10) rotation abnormality. Since an error is detected when M10 turns ON, turn it OFF. An error is still detected when turn it ON again.Air separation motor (M10) Air motor encoder sensor
(PS30) Resetting of the intermediate toner hopper section. Have a tech come out to check out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to fix 2231 error code?
Could be one of these, start first with the Y drum
Anything else get a tech out power supplies and printer control boards are serious money$$$$$$$$$$$$$$$
• Printer control board
(PRCB)
• Drum motor /Y (M14)
• Encoder sensor /Y1
(PS81), /Y2 (PS82)
• DC power supply /2
(DCPS2)
• Drum Unit /Y
1helpful
2answers
Allwin konica 512 flex printing machine was not worked on 6 months without maintenance now what r t problem was accured...??? and how to solve it...???
1st of all heads must be deeped in solvent for 5 hours
then take a injection and remove all color clogged
then adjust a ink motor to one head & spray for 30 min one by one head try it & then contact [email protected]
1helpful
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
1helpful
How can i change the ISO on my camera (minolta maxxum 3xi)? The film i put in is 400 but the assignment requires me to change it to 100
Okay. Just bear in mind that the exposure meter is going to be two stops off, unless you're getting the film pull-processed.
The Maxxum 3Xi unfortunately does not have a way of overriding the Camera Automatic Sensing portion of the DX encoding standard. That is, if the film cartridge has the DX encoding, the camera will set itself to the indicated speed.
However, if the film cartridge is NOT encoded, the camera will set itself to ISO 100. So, if you tape over the magnetic encoding on the cartridge...
The CAS is not the barcode on the film cartridge, but the rectangular patches of conductive and nonconductive material.
Take a look at http://en.wikipedia.org/wiki/DX_encoding for more information about the DX encoding.
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
