SOURCE: Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at [email protected]
SOURCE: xerox majestik 5765 error codes
Sorry I am not familiar with this machine, usually if you press the start key for 3 sec it should show you the other codes? Good luck.
P.S.: If i run into anything I'll send it to you .
SOURCE: 405 canon code e604 error ir machine xerox
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity
