Question about Yamaha Boating
Need to know about a clicking noise motor won't turn over 97 Yamaha 75 horse boat motor
    New Friend:
  • 22 Answers
Most likely, (1) it's an old worn out battery, low charge, poor or corroded cable connections. Inspect and clean them. You may want to jumper battery with your car battery. If problem persists, (2) check starter solenoid connections and output connections. (3) As a last culprit, it could be a bad starter. And make sure your engine is not frozen. (Take spark plugs out and turn the flywheel by hand).
Posted on Sep 29, 2019
6ya staff
SOURCE:
Anonymous
  • 957 Answers
SOURCE: 85 horse motor
Always check for fuel and spark first. Find out what you don't have and we'll go from there. The more info the better.
Posted on May 03, 2009
Anonymous
  • 3 Answers
SOURCE: I have a 90 Horse power Mercury outboard Boat
Sounds like the starter. Check if you have power at the solenoid from the battery with just the power on (key turned on, power switch on.) thats good-- you have power-- if not you have a wiring problem from your battery or main switch.
Otherwise you have a starter problem probably.
Posted on May 17, 2009
Anonymous
  • 207 Answers
SOURCE: 75 mercury boat motor not turning over
you have one of two problemsyour starter brushes are sticking or your solenoid is going bad next timme it happens take a hammer and lightly tap the starter if it turns over your starter is going bad if you try this repeatly and nothing then you have a bad solenoid they are not expensive if you do not want to tap the starter then just replace the solenoid the best way to find it is follow your main battery line to motor where it stops and breaks with two posts and then the hot goes to the sarter take a picture of it so if you need to take it with you u acn see where the wires go oriellys probally will have it is round and you battery will go to one post and the hot to the starter will go to the other there will be to little posts on it as well one to the key switch and the other is a groud
Posted on Jun 30, 2009
Anonymous
  • 85 Answers
SOURCE: 85 horse boat motor
check the spark plug and check the fuel filter. if still no response check if there is spark comming out of the spark plug
Posted on Sep 22, 2009
AndrexT
Andrew Taylor
  • 30497 Answers
SOURCE: Our Yamaha 115 motor won’t tilt/lift. Clicking noise but nothing happens, boat battery is fully charged
Take of the tilt unit and take it apart, look for worn parts, or take it to a marine engineer. You probably need a new unit. There are two types though, hydraulic and manual.
There are videos and text in the link to help you. This is a well known problem by the looks of it.
yamaha 115 tilt trim problem Google Search
Posted on Dec 23, 2017
Dec 23, 2017 | Yamaha Boating
2000 mercury 75 horse wont idle or run trimmed down but runs and idles trimmed up
Good Day
The Carburettors Need Servicing And float Levels Adjusted correctly
Apr 02, 2017 | Mercury Mark 75 Outboard Boat Motor...
I have an older model stejcraft stallion 5.2 mtr cuddy cabin and need to know the weight of the boat and it has a 75 yamaha motor
Google the weight of the stegecraft then the motor, I did this recently so I could work out the weight I would have on my trailer.
Feb 14, 2017 | Yamaha Boating
Boat impeller
Undo gearbox bolts,take off trim tab,undo bolt in trim tab cavity,disconnect speedo tube,pull off gearbox. You will see pump housing,undo 4 bolts,pull off housing exposing impeller,there maybe a clip on top of impeller depending on model,pull off clip then impeller.yamaha didn't make outboards in 75
Aug 25, 2014 | Boating
Waterpump impeller 15 hp yamaha 2 stroke how hard to renew
It is not going to be hard at all. You will have to pull the lower unit which with a 15 horse motor will not be that hard, so you could probably do it by yourself. Mine is a 150 horse mercury and i normally have one other person help me.
Feb 23, 2012 | Boating
Yamaha outboard 8 horse power tilt removel trouble
Trouble removing it from the transom? Is it C clamped into the transom? Or a bracket built of the transom?
Nov 07, 2011 | Light Outboard Motor Boat Bass Fishing...
I need to know the ratio of a gas and oil mix for a 1999 yamaha outboard motor 90 horse power already broke in...
I'am amazed it doesn't have an oil premix that gives it auto oil mix.If it doesn't than the mixture is 50/1.That is fuel /oil ratio.e.g. 50 litres of fuel to 1 litre of oil.Hope this helps
Apr 17, 2010 | Boating
Boating Logo
51 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
