How can I add sequential numbers to karaoke mp4 files
Tip
The best way to convert FLV to MP4
1. What is Flash video FLV?<br /> FLV, short for Flash video, is a video format played in Adobe Flash Player. If you download a video from YouTube, Google Video, Yahoo! Video, DailyMotion etc, it is most likely a Flash video with the file extension .flv. With the wide availability of Adobe Flash Player in most common web browsers, Flash video has become the most popular format for online video delivery!<br /> 2. What is MP4?<br /> MP4, short for MPEG-4 Part 14, is a multimedia container format standard specified as a part of MPEG-4. It is commonly used to store digital audio and video streams, especially those defined by MPEG, it can also be used to store other data such as subtitles and images. Like most modern container formats, MPEG-4 Part 14 allows streaming over the Internet. The official filename extension for MPEG-4 Part 14 files is .mp4, thus the container format is often simply referred to MP4.<br /> 3. How to convert FLV to MP4.<br /> Convert FLV to MP4 is for playing flash videos on different devices like iPod, Apple TV and so on. Generally, there are two ways to convert FLV to MP4: either to convert FLV to MP4 with online conversion services, which can be easily searched in Google or to convert FLV to MP4 with FLV to MP4 converter like FLV Converter. This FLV converter can perfectly convert FLV to MP4, convert FLV to many other more popular video/audio formats. Using the video editing functions it has provided, you can get your flash video cropped, trimmed and logoed during the FLV to MP4 conversion. The tutorial below will show you the easiest way to <a href="http://www.mediaconverter.biz/guide/convert-flv-to-mp4.html">how to convert flv to mp4</a>.<br /> <img src="convert-flv-to-mp4-1.jpg" /><br /> Step 1: Launch <a href="http://www.mediaconverter.biz/">DRM Media Converter</a> and click "Add" to input FLV files.Click "Add File(s)" button on the toolbar or "File &gt; Add File(s)" to load FLV files you want to convert. Or click "File &gt; Add Folder" option to add all files in the folder you select.<br /> All the loaded files will be displayed in the file list, and are all checked by default.<br /> Step 2: choose output format.<br /> The default output format is the one you selected last time. If you want to change the output format, then choose the file, click to open "Profile" drop-down list below the file list or in the "Target Profile" column, and choose the desired format from it. Click "Browse" button to set the destination folder for saving the output files.<br /> Step 3: convert<br /> Make sure all the files you want to convert each have a check box next to them, and click the "Convert" button on the toolbar to start converting all the checked files in batches.<br /> More source: <a href="http://www.mediaconverter.biz/guide/convert-mp4-to-avi.html">best mp4 to avi converter</a>, <a href="http://www.mediaconverter.biz/resources/convert-mp4-to-dvd.html">how to convert mp4 to dvd</a>.<br />
on Apr 27, 2011 | Computers & Internet
How do I get the lyrics to play on the screen using the karaoke anywhere app? I hear the music but there's no lyrics
The Karaoke Anywhere app will play standard MP3+G zip files. These contain two files. One must be an mp3 file and the other must be the accompanying cdg file. The zip file cannot contain any other files or folders.
It seems from what you describe, the file you are attempting to play through Karaoke Anywhere is an MP3 file but that it either does not have a proper CDG file, or the MP3+G zip file is not in the proper format.
Sep 01, 2014 | Sakar The Voice I Want You CD G Karaoke...
Tip
Mac TiVo Converter for iPad-Convert HD TiVo to iPad How to convert TiVo for iPad...
How to convert TiVo for iPad on Mac? To solve this problem, you need to transfer TiVo to your Mac and then convert them to iPad mp4 format with TiVo converter. With our recommended software, you can convert TiVo to iPad mp4 by yourself fast and easily!
How to convert TiVo to iPad mp4 step by step
This guide has 3 parts:
Parts 1: Transfer TV shows from TiVo to Mac
Parts 2: Convert TiVo to iPad MP4
Parts 3: Sync MP4 to iPad
To transfer TV shows to Mac, you need to download TiVo Desktop Software for Mac
Parts 2: Mac TiVo Converter for iPad
After you transfer TiVo files to your Mac, you can convert them to iPad mp4 format. First of all, Download TiVo to MP4 Converter and launch the application. Then follow the steps below:
Step 1: Import TiVo files to TiVo Converter
Enter Media Access Key for your TiVo files from "Option" button and then load TiVo files to the TiVo converter.
When your TiVo is connected to your home network, TiVo Desktop provides you with a list of available shows for transferring to your Mac.
Hints: TiVoToGo Transfers system requirements: TiVo Series2 DVR, TiVo software version 7.1 or later, TiVo Series2 box must be connected to your home network using a wired or wireless USB network adapter.
Step 2: Edit TiVo files
Editing functions are available by clicking "Editor" button in the menu bar. You can crop, trim, add text/image/video watermarks, replace audio, add special effects, etc. you can check "Apply to all" to apply the present settings to all the TiVo files.
Step 3: Choose iPad MP4 output format
After you finished editing, you then choose output format from "Format" drop-down list and specify the format under iPad profile among the three options.
Step 4: Convert TiVo to iPad MP4
Click "Convert" button to start Convert TiVo to iPad mp4. Check "Merge into one file" to join all TiVo files to one output mp4 file before start conversion.
After converting your TiVo to iPad format, you will get mp4 file(s) in destination folder. Then you need use your iTunes to transfer the mp4 file(s) to your iPad device. You may refer to the help document of your iTunes to learn how to do, or you may follow the steps below:
1. Connect your iPad to Mac. And then launch iTunes.
2. Click "File->Add File to Library...." to choose the generated mp4 file
3. Drag the videos you just added to iPad icon.
Now you are free to enjoy your TiVo recordings wherever you go.
on Jul 31, 2010 | Cell Phones
Tip
Tired of Converting WMV to iPad MP4
Have you ever spent several hours and been tired numerous different videos converters to convert WMV to iPad MP4
Aimersoft Media Converter - a powerful WMV to iPad MP4 converter permits you to convert WMV to MP4 for iPad freely. Free trial is available. If you don't know that How to convert WMV to iPad professionally, you can watch the following content. It will let you convert WMV to iPad MP4 as a specialist.
Here a guide will show you how to convert WMV to MP4 for iPad for watching on the iPad step-by-step. It just takes a few clicks to convert WMV to iPad MP4 files using this WMV to iPad MP4 converter software.
Guide: How to Convert WMV to iPad MP4
Step 1: Install and run the software.
Step 2: Click the pull-down menu pointed by the red arrow to add WMV files.
add your wmv files to the converter
Step 3: Choose the iPad MP4 format by clicking the "Setting" button.
choose the ipod mp4 format for your conversion
Step 4: Click "Start" to begin your conversion.
begin the wmv to ipad mp4 conversion
Now, you only need to transfer the converted files to iPad. Then you can enjoy your favorite files at anytime and anywhere on your iPad.
Connected information : music converter media converter ipod to mac iphone to computer ipod transfer
on Jul 23, 2010 | Computers & Internet
What is code 28
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } I bet people who use Sony and Cannon camcorders may feel frustrated trying to enjoy their videos on iPod, iPhone or iPad, as these videos are taken and saved in the form of mts/m2ts and they cannot play on these players. It used to be my trouble, too, but then I found I needed to convert mts to mp4. I found some powerful mts to mp4 converter so I'd love to share it with all you guys.How to convert mts to mp4?
Download and install mts to mp4 converter on your PC. It takes only a few steps to convert m2ts to mp4 on Windows.
Step 1: Connect your HD video camera/camcorders to your PC. Copy the source videos to your PC's hard-drive before converting or editing them.
Step 2: Launch the m2ts/mts to mp4 converter. Click "Add files" to browse your computer hard disc and add the .mts or .m2ts files you want to convert. You can load all the source files before the mts to mp4 conversion as batch converting is supported by this m2ts mp4 converter.
Step 3: Now you select mp4 as the output format and specify a directory for the output files. This mts/m2ts to mp4 converter supports comprehensive video formats including avi, mpeg, wmv, mp4, mov, xvid, 3gp, flv and more.
Step 4 (optional): The mts to mp4 converter can set the brightness, the contrast and the saturation of your videos, crop, trim videos and even merge multiple files into one single file before the conversion.
Step 5: Click the "Start "button to start the mts to mp4 conversion and all you have to do is to wait until the m2ts mp4 conversion is done.
Related article: How to convert m2ts to mp4 and How to m2ts/mts to mp4
Oct 04, 2010 | Microsoft Windows XP Professional
Tip
How to Convert WMV to MP4?
question.png I have a bunch of HD WMV video files. I want to convert WMV to MP4 while not descending the quality of them to work on my iTunes iPod. Where can I find such a WMV to MP4 converter?
Answer: There are plenty of WMV to MP4 converters on Google while rare of them can convert HD WMV to MP4 by keeping the original quality --- except Aimersoft Media Converter, the best WMV to MP4 Converter that can convert both HD wma and SD wmv video files to MP4 with high quality, because it's adjustable output file settings enable you to convert WMV to MP4 with customizable video quality layers.
freetrial.gif buynow.gif (Only $35.95) Guide: Convert WMV to MP4... How to convert WMV to MP4? Check this guide you'll find it is so easy to convert WMV to MP4:
Step 1: Add WMV Files
Free download DRM Media Converter and run it, then click "Add" button to load WMV files.
load-file.jpg Step 2. Select "MP4" output format
You can set your output settings as follows:
mp4-settings.jpg Step 3. Start converting
Click "Start" button to begin to convert WMV to MP4, that's all.
resource:drm remove
on Jun 03, 2010 | Cameras
Tip
How to burn MP4 to DVD on Mac OS X
Want to convert MP4 to DVD on Mac OS X?
MP4 is the official multimedia container for MPEG-4 video and audio, which is widely used on iPod, iPhone, iTunes, PlayStation Portable (PSP), etc. If you have a few of MP4 videos and movies and want to watch with DVD players connected with TV on the big screen, or to keep the movies, share with friends and family, burn MP4 to DVD is a good choice.
What you need to burn MP4 videos to DVD on Mac OS X?
To burn MP4 files to DVD, you need a DVD burner that can convert MP4 to DVD on Mac OS X(including Mac OS X 10.4 Tiger, Mac OS X 10.5 Leopard, Mac OS X 10.6 Snow Leopard). Nero 9 and Daniusoft DVD Creator for Mac are your solutions. Nero is a powerful DVD Burner that performs many functions and is a bit complicated. In contrast, Daniusoft DVD Creator for Mac is much more user-friendly and meets all your needs such as burn videos and photo slideshows to DVD, add DVD menu, edit videos and pictures, add transitions and effect, etc.
Below is the step by step guide on how to burn MP4 to DVD on Mac OS X
Step 1. Load files
Just click “+” button to import MP4 files to this program or simply drag and drop them to it. And rearrange the file list by using the up-down arrows.
Step 2. Edit files (Optional)
To personalize your DVD files, you can edit MP4 files and slideshows as well by clicking “Edit” button. For video files, you can crop the frame size, trim into several clips, append effects, add picture/text watermark and rotate.
Step 3. Create DVD Menu (Optional)
This Mac DVD Creator also allows you to create your own DVD menu with rich selections of DVD menu template. Simply click “Menu” button to select one and set the “Frame”, “Button” and “Text” to customize your DVD menu
Step 4. Start to burn
After all necessary settings, you need to insert a blank or rewritable disc to your Mac if you want to burn video files on DVD disc. Or you can simply convert the videos to DVD folder, .dvdmedia or ISO file on your Mac for later burning.
That is it! Now, with MP4 movies burned onto DVD, you can easily play your videos on your home DVD player
on May 21, 2010 | Computers & Internet
Tip
How to convert MOD to AVI MPEG WMV MP4 VOB 3GP?
This is an article about what is MOD format, how to convert MOD files to AVI MPEG WMV MP4 VOB 3GP.
What is MOD?
The .MOD format is simply a MPEG-2 video file, often used by various digital camcorder models to save their videos. And you may get your MOD files from the following camcorder models:
JVC: GZ-MG30, GZ-MG70, GZ-MG37, GZ-MG77, GZ-MG505, GZ-MG130, GZ-MG155, GZ-MG255, GZ-MG555
Panasonic: SDR-S100, SDR-S150, SDR-S10, SDR-H18, SDR-H200, SDR-H40, SDR-H60, SDR-SW20
Canon: FS100, FS10, FS11
Why convert MOD files to AVI MPEG WMV MP4 VOB 3GP?
Since MOD files are not widely accepted, if you want to play MOD files on windows media player, windows movie maker, iPod/iPhone, Blackberry, PSP, Zune, Creative Zen or others multimedia players, you may need to convert MOD video files to other popular formats like AVI MPEG WMV MP4 VOB 3GP. Then you can share your MOD videos with your friends with any player and family by uploading them to YouTube, Facebook or Myspace.
Therefore, you may need a Video Convert to help you convert MOD files to AVI MPEG WMV MP4 VOB 3GPB. Free download Aimersoft Video Converter here.
http://download.aimersoft.com/aimer-video-converter_full68.exe
How to convert MOD to AVI WMV MPEG MP4 VOB with Best Video Converter ?
Step 1. Import MOD files to Aimersoft video converter
Copy the MOD file from your video camera to your hard drive, click “Add” to browse your computer hard drive, and upload the MOD files you want to convert. And the best Video Converter automatically scans and displays the MOD file you have chosen.
Step 2. Select output settings
Select the proper output destination folder and your desired output format.
If you want to convert MOD files to other video format for portable device, but you don’t know which formats your device supports, you can simply select any format in the category of your device.
Edit the video files
If you want to edit your MOD video files, this MOD video Converter offers you powerful video editing functions.
Trim – you can easily trim your MOD video into multiple segments by moving the sliders or just typing the number in manually.
[img]http://www.aimersoft.com/images/tutorial/video-mod-to-wmv-trim.jpg[/img]
Crop – You can crop the black bar and get what you want by setting the video zoom to full screen, 16:9, 3:4 or others.
[img]http://www.aimersoft.com/images/tutorial/video-converter-crop.jpg[/img]
Add effect – Configure the brightness, contrast, saturation, and add special effects like Gray, Emboss, Negative, Old Film to personalize your MOD video.
[img]http://www.aimersoft.com/images/tutorial/avchd-to-wmv-effect.jpg[/img]
Add watermark – If you want to add some image or text watermark to decorate your video, you can click “Watermark”. It also allows you to configure the parameters such as transparency, vertical space, and horizontal space.
Step 3. Start to convert MOD files to AVI MPEG WMV MP4 VOB 3GP
Simply click “Start”, you can start your conversion from MOD to AVI WMV MPEG MP4 VOB.
After you convert MOD to AVI MPEG WMV MP4 VOB 3GP, you can easily import your MOD files to Windows Movie Maker, iPod, iPhone, Zune or others multimedia players with this Aimersoft Best Video Converter.
on Dec 30, 2009 | Audio Players & Recorders
65 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
