SOURCE: Big Green Machine
Go to Bissell.com and see if a user manual is available for download. You will need your model number tho.
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
SOURCE: how do i attach my upholstery cleaner to my kirby generation 4?
Upholstery shampoo manual HERE.
Good luck,
Rocky
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
SOURCE: Bissell spray to floor not operating. Spray to upholstery fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
urr
