Question about Video Game Consoles & Games
Need to purchase a pair of PEC R4 sensors - Video Game Consoles & Games
Raynor garage door motor won't run and won't open the door. It is not sending power to the system despite being plugged in to a working outlet.
More than likely, the transformer in the opener is fried. You need to verify 110V power coming into the transformer, and that there is 24V AC power coning out of the transformer
Oct 03, 2014 | Raynor Garage Doors 4050047 Raynor PEC-R4...
DS doens't recoginize R4 card in my sons DS Lite. My other sons DS does recoginize the R4 card. Why? how can I get the card to work in both DS Lites.
Make sure you bought the correct R4 for the DS light and not the DSi. If you bought the correct one, then it sounds like the R4 cartridge is defective and needs to be exchanged for another one. Remember, Nintendo does not support the R4 cartridge, so go back to where you purchased it from.
Mar 23, 2011 | Nintendo DS Lite Console
I have a r4 card that I purchased. It has a 2GB micro chip in it with several games already downloaded on it. The R4 card says Revolution for DS (NDSL/NDS) My question is why will it not work on my...
The R4 was Made in 2004 and the production stopped in 2008. And DSi has Firmware that the R4 Will NOT Work with the R4. I advise you to use an R4i or something else.
Nov 08, 2010 | Nintendo DSi Black Console
I have purchased an R4 card and micro sd card for my DS. I have been told that I need to download the software for it, does anybody know what software I need to download before i can transfer my games onto...
google R4 revolution or R4 card. You will see a host of websites. Each one will have a download for the card... Your best bet for finding the correct kernel is to go to the website that you purchased the card from and there should be a link to download the firmware( kernel ) for the card. Once you get the firmware you will need to transfer that onto your micro sd card using the TF adapter that should have come with the R4 card. Make sure you transfer everything over to the micro .... After you get the info onto the card make folders for your media. Label them correctly so you can find them on your ds. Label one music one movies one games. After that is done insert your micro sd card into the R4 and plug it into your ds... have fun ..these cards really open the ds up to a ton of neat and fun programs
Feb 04, 2010 | Nintendo DS Lite Console
2nd R4 Card doesn't work
Hello there,
The original R4v2 card only accepts up to 2GB Micro-SD cards, while subsequent R4 SDHC and R4v3 cards will accept 4GB cards and higher. It's likely that you didn't purchase the same type of card the second time around.
If you are looking for a reliable place to buy DS and DSi cards fromthat will stock originals, I'd recommend using http://www.NDS-Gear.com(I've used them myself). They test every card before sending whichmeans you won't receive dud cards, and more importantly they havesupport before AND after your purchase by people who reply very quicklyand in perfect English. Some of these dodgy websites take 4-6 weeks todeliver and never answer e-mails, so I'm glad these guys are different.Oh, and they guarantee to dispatch by the next working day, whichalways helps with speed and all. And they're recommended by a lot ofthe DS card help sites, too.
Feb 10, 2009 | Nintendo DS Lite Console
Problem with r4 and ds lite
Try the paper shim trick first. It could be that the older NDSL's slot one contacts have become "sprung" and aren't making good contact.
Cut a piece of paper slightly narrower but longer than the R4. Put it on the non-contact side of the R4 and insert the R4 (with the paper on the back) into slot 1. It may increase the thickness of the R4 such that the slot 1 fingers now make contact.
Jan 12, 2009 | Nintendo DS Lite Console
Images blurry after sensor cleaning
If you were careful while cleaning, I'd guess the cleaning solution just left a haze on the sensor then, and you might want to try again. Maybe use less solution this time. Hard to say without seeing an example.
Sep 14, 2005 | Canon Digital Rebel XT / EOS 350D Body...
Video Game Consoles & Games Logo
59 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
