SOURCE: my turtle beach x1 headset
Do you have your play n' charge kit plugged in? if so, then thats what is causing the buzzing sound
SOURCE: my turtle beach x4 headphones work but the sound is distorted
Try moving the receiver away from major electronic objects and move yourself closer to the receiver. Does this make any difference? If so, it's interference.
Try replacing the batteries in the headphones.
SOURCE: the mic is not working on my X1 turtle beach
I have fixed this. Beleive it or not they have miswired the cable (from the Earforce Amp) end at the controller which houses a small cct board (inside the hockey puck) that controls the voice volume control.You need to reverse the Red and Black wire solder points(from the amp) so you will need some skill with soldering. I did this and tested the mic now works with the dial adjusting the voice vol.
Turle Beach needs to do a massive recall on these X1s; how can you realese a fairly expensive product like this that does not work out of the box. And they have removed all the forums from their web site concerning this as they know they have a faulty product,
SOURCE: I cannot hear voices through my Turtle Beach X4's.
you will need to press the middle guide button
go right to settings
then down to preferences
down to voices
then select play through headset
SOURCE: buzzing noise coming throught my headset on my
Check if the buzz stops when you remove the talkback cable. If so, then try a wireless controller if you're using a wired one. Also, don't use a play and charge kit because it causes a lot of buzz on the headset.
