Question about Ryobi Garden
Can I get a replacement bottom shaft bearing for a Ryobi RLT 1038x line trimmer.
    Top Expert:
  • Ryobi Master
  • 55,370 Answers
Possibly, but not from fixya
Posted on Sep 29, 2019
6ya staff
SOURCE:
Platistay
SOURCE: Ryobi 105r replacement line
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
Posted on May 19, 2008
Anonymous
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Posted on May 18, 2009
Anonymous
  • 8 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Posted on May 20, 2009
Anonymous
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: Ryobi 700r 31cc 15" Trimmer,
Hi and wel;come to FixYa, I am Kelly.
The part you need is item 9 on most parts lists:
Your problem is caused by either drive shaft failure or.. clutch failure. Most of the time the drive shaft fails before the clutch.
The manual is here:
http://www.mymowerparts.com/pdf/Ryobi_String_Trimmers_Blowers_Tillers/700r.pdf
Shaft is PN 682064 or 753-04280
Sears parts direct has the shaft as item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/Model-700R/0909/1503820/10060718/00002?blt=06&prst=0&shdMod=700R
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/753-04280/0071/247/Model-700R/0909/1503820?keySuffixId=NA&productTypeId=x&searchModelNumber=700R&subCompDesc=Boom%20and%20trimmer&brandDesc=RYOBI&modelDesc=TRIMMER&pathTaken=partSearch&blt=11
Lower price here:
http://www.mowpart.com/p661995/Flex,-Shaft-(Rpls-682064)/product_info.html
Average price ($32.50)
Thanks for choosing FixYa,
Kelly
Posted on May 29, 2011
How do i get trimmer line holder cap off my electric ryobi trimmer rlt 1038
Hi, I wished I had read this before I bought my rlt1038, I used it for
8 mins and 1) long grass caought around the drive head, 2) I tried to undo the screw holding the line head. Fortunately I have a wide pair of foot prints to go across the line head and a central heating pump adjustable spanner- after 5 mins I had undone it. Yet another bad design !
Good Luck
Mar 16, 2013 | Ryobi 15" Electric Factory Reconditioned...
I HAVE A RYOBI RLT 580. MY PROBLEM IS THAT THE COVER ON THE SPINDLE BROKE .THIS IS THE COVER THAT CLOSES THE LINE AND SPRING AT THE BOTTOM. NEED A NEW ONE. CAN ANYBODY HELP ME
This is all I could find for that model. Very little info is available on the RLT580, but I am sure you can get the part you need somewhere. Is this unit GAS or Electric?
http://www.ereplacementparts.com/search_result.php
Sep 05, 2011 | Ryobi 15" Electric Factory Reconditioned...
I inherited this trimmer and do not know how to add new string. There isn't any kind of a manual that we can find. The trimmer is a RYOBI 137R. Thank you.
hi i have a ryobi rlt 30cd strimmer and when i was useing it it just stopped it as fuel in it but ive cleaned the carb but i still cant get it to run as any one got any ideas thanks
Jul 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Where can I get a repair manual for a Ryobi rlt 900 trimmer ?
Go on line at RYOBI and you can down load it for free.
Jan 15, 2010 | Ryobi Garden
I have a Ryobi RLT 30CESA with the strimmer attachment. What do I need to fit a Brushcutter blade to it
I would not put a brushcutter blade on this unit. The curved shaft quik disconnect may not hold up to the shock torque created by the brushblade. It may damage the drive shaft since it is a curved shaft quik disconnect model. You may have to purchase a straight shaft trimmer to get that job done.
Oct 02, 2009 | Garden
Have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Oct 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
52 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Dennis Tokarzewski
Level 1 Expert
Wayne McNeil
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
