The CL message indicates that the voice clock has not been set and the answering system is off. Check that the clock has been set by pressing the Day/Check button on the side of the base. Press as needed to get to the current day of the week. (The Day/Check button is the third button from the top.) Press the Min (top) and Hour buttons to access the time set mode for them. Press the Day/Check button to set the current time. Press and hold to rapidly adjust the time (5 minutes or 5 hours at a time).
The manual is available here: https://fccid.io/ANATEL/00942-05-02639/manual/865AA947-5DF8-4B4B-BDF6-AA1D87E1BC5C .
I hope this helps.
Https://manualzz.com/doc/2128477/ge-27990ge3-cordless-phone
The voice time of day stamp needs to be set.
SOURCE: "CL" blinking on the display of my answering machine
CL is the clock. Set the time and date on the lower right hand side of answering machine.
SOURCE: answering machine is flashing CL after I lost power
set the CLock by holding down the buttons on the side of the answering machine - top button for day, middle button for hour, bottom button for minute
SOURCE: Wharfedale DECT TAM telephone/answer machine
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct
year on the handset numeric keypad and then press OK. (Only the last
two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
SOURCE: System keeps flashing with CL
Program the clock. There are a some buttons on the back of the base unit that sets day of the week, hour, and minute.
