I would like to know, how to set up a new developer in the service mode.
SOURCE: how to get into the service mode
press button C & 8 at the same time to show u the error no. its the error no that will let u know the fault type.
SOURCE: I need Know, How enter to service mode
Press,,,,, Menu #1934 . What you may want to try first is to do what is called the Shading adjustment. That calibrates the scanner.
It would be found in the maintenance menu after you enter diagnostics.
You must place 5 pieces of white paper on the glass before you perform the adjustment.
There really is no way to increase the amount of toner concentration on that machine. You may very well have a defective ink cartridge. That is not uncommon on the C20. There is a metering blade in the toner cartridge that often times does not allow enough ink to be applied to the toner roller.
SOURCE: How to install developer in a new Ricoh Aficio
I suppose you have the developer in the developer unit, YES????
If so you just need to do developer initialization.
Press yellow key.
press on the key pad 107.
Old red key at least 3 sec.(if you did everything well you are in SP MODE)
Press 1 (to copy sp)
Search 2 drum (one time on the left key)
Press ok
Search SP 214 Developer initialization
Press execut
Hope you understood. Good luke.
Testimonial: "Thank you so much! This is what I need"
SOURCE: How can I enter service mode in panasonic workio
To enter service mode press FUNCTION, ORIGINAL SIZE (LEDGER/A3) and 3 keys simultaneously then F1 will appear. Press 8 on key pad and F8 will appear, press start, select 09 then ok or start and this will run developer for a few minutes. when done press FUNCTION and C (CLEAR) keys to exit service mode.
