Vtech VT 2461 Cordless Phone Logo
Anonymous Posted on Dec 12, 2007
VT2461 ADDITIONAL HANDSET PROBLEM
I HAVE THE VT2461 ANSWERING MACHINE AND 3 HANDSETS. RECENTLY ONE OF THE HANDSETS (LABELED HANDSET #3) BROKE SO I WAS ABLE TO PURCHASE A REFURBISHED HANDSET WHICH WORKED FINE AND REGISTERED THE ADDTL HANDSET AS #4. I DID NOT REALIZE THAT THIS MODEL COULD HAVE 4 HANDSETS SO I BOUGHT A NEW ADDTL HANDSET AND ANOTHER REFURBISHED HANDSET AS MY FOURTH. HOWEVER, WHEN I PUT EITHER OF THESE TWO PHONES INTO ITS BASE, IT KEEPS SEARCHING FOR BASE. I HAVE UNPLUGGED ALL THE PHONES, TAKEN OUT ALL THE BATTERIES, REPLUGED THE PHONE, RETURNED THE BATTERIES AND 3 HANDSETS REGISTER. BUT THE SYSTEM WILL NOT REGISTER THE SPACE FOR HANDSET #3. I HAVE TRIED SWITCHING OUT THE HANDSETS BUT THE SYSTEM JUST DOES NOT SEEM TO RECOGNIZE THAT i AM NOT REGISTERING A 5TH HANDSET (SINCE THE MAX IS 4), BUT AM JUST REPLACING ONE OF THE HANDSETS (HANDSET 3). HELP.
  • 1 more comment
  • Anonymous Dec 12, 2007
    Well, I think I might have solved my own problem. I had emailed vtech about my problem and below is their solution. I have not tried it yet, but will let you know how it goes. I thought I would share what they wrote with the group.
    To be able to register your replacement handset, you must de-register all the handsets from the VT2461 base unit. Follow the steps below to de-register your handset(s) from the VT2461 base:
    For the VT2461 base unit (with a Tone or Pulse switch at the bottom of the base), take the handset out of the base, and any spare battery inside the base.
    1. Unplug the base from the power outlet. Wait approximately for 10 seconds.
    2. Press and hold down the PAGE button, and then plug the AC adapter in.
    3. When the POWER light blinks, release the PAGE button.
    4. Hold it down for 5 seconds.
    5. When the LINE IN USE light begins to flash, release the PAGE button.
    6. The HANDSET CHARGING light on the base will blink 5 times.
    7. Within 5 seconds from when it stops blinking, press the PAGE button once.
    For the VT2461 base unit (without a Tone or Pulse switch at the bottom of the base), take the handset out of the base, and any spare battery inside the base.
    3. When the display on the base says “Pr”, release the PAGE button.
    4. Press MENU, the display would say “rh”.
    5. Press SELECT repeatedly and choose “AL”.
    6. Press TIME/SET to confirm.
    7. Unplug power from the base and then reconnect power to complete de-registration.
    You must register the handset(s) by following the steps below:
    1. Make sure to charge the handset battery pack for at least 12 hours.
    2. If the handset display shows "SEARCHING FOR BASE", press the soft key to select “NEW”. "ENTER BASE ID" will appear on the
    screen.
    3. Enter the 15-digit Base ID code located on the underside of the VT2461 base. The 15-digit Base ID code may contain numbers
    and characters, including 0 through 9 and *. Make sure you enter all 15 digits.
    4. Use the soft key to select “OK”. The screen displays “PLEASE WAIT!”. After about 15 seconds, the screen should say “FOUND
    BASE”. If the handset displays “BASE BUSY TRY LATER”, the base unit is in use.
    I contacted vtech and they actually wrote back with the solution. I tried it and it worked. Below are the the instructions they sent. I used the first set of instructions since the bottom of my base had the tone/pulse button. You have to be very precise in following the instructions. I unplugged and removed the battery from all 4 handsets and chargers as well as the battery from the base. Then it was important to only press the page button once at the very end. Then, as I plugged in each handset and returned the battery, each handset indicated rejected by base and automatically gave the screen to enter the base id. I entered the base id, and for all 4 handsets the base was found.
    screen.
    We apologize for any inconvenience this may have caused.
    VTech Communications
    Consumer Sales and Service Center
    Hope this helps some of you out there!
    screen.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
712
Points
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
How do I leave a message for my answering machine
Ask the service provider
Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
change amount rings panasonic kx tg7643 Answering ...
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 OK SYNC" same as below
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 ...
www.faqqq.com/.../lg-aria-phone-showing-ldp-7016d-v1-4-scout-dx-v1...
Question Product: Phones Question Details: Lg aria phone showing "LDP-7016D V1.4SCOUT-DX V1.1 OK SYNC" same as below View Answers Search ...
LG Aria 130 & LDP-7016D Handset Issue - LG / Goldstar Systems ...
www.tek-tips.com/viewthread.cfm?qid=1694833
Oct 3, 2012 - I recently purchased 3 additional LDP-7016D handset for our phonesystem, but have ... System is a LG-Nortel Aria 130 running 7 handsets 1 x LDP-7024D Handset (V1.4) 6 x LDP-7016D Handsets (5 x V1.4 and 1 x V1.5)
9helpful
3answers
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
2helpful
2answers
Have just bought a second hand BT mango telephone with 2 extra handsets.There doesn't appear to be anywhere to connect the phone wire to handsets 2 and 3. Only a socket for the power supply. Is this right?
There isnt a socket to connect the additional handsets because it is not needed. The handsets all use a single line by connecting to the base unit. You need to make sure the additional handsets are registered to the base unit.
For how to do this and anything else look in the manual which can be downloaded for free at http://phone.manualsonline.com/manuals/mfg/british_communications_bt/bt_mango_1_2.html
3helpful
How do you register a waterproof phone (TWX977) to a TRS9585
Not sure if you still have this problem, but...
Basically go on you base unit, and hit "MENU/SELECT". Scroll down to "REGISTER HANDSET" and click "MENU/SELECT". On your waterproof handset, hold the "#" key until it displays "REGISTERING HANDSET". And voila! After that finishes, your waterproof handset will be good to go!
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
4helpful
4answers
VT 2461 Won't let me register new handset
jimmackey
were you ever able to register the additional handset? I have the same problem with 4 handsets, one broke and I bought 2 new vt2420 handsets. The unit wont register handset #3 (the one that broke). Would love to know if you were able to resolve the issue?
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
