Question about Mitsubishi Televison & Video
I have a Mitsubishi 73" flashing red light no sound no picture
  • pilafiv
    pilafiv Oct 07, 2019
    ?I get paid over $426 1 to 2 hours working from home with 2 kids at home. I never thought I'd be able to do it but my best friend earns over $28k a month doing this and she convinced me to try. The potential with this is endless. Heres what I've been doing......
    HERE?  www.more55.com    ???COPY THIS SITE???
    Top Expert:
  • Mitsubishi Master
  • 30,377 Answers
You will be needing a Mitsubishi service technician to fix that one.
Posted on Sep 26, 2019
6ya staff
SOURCE:
Priya darshan
  • 3422 Answers
SOURCE: No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
Posted on May 03, 2008
Anonymous
  • 252 Answers
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Posted on Oct 14, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Posted on Apr 13, 2009
Anonymous
  • 100 Answers
SOURCE: red power light flashing..no picture
Count the blinks of the led. The number of blinks gives an idea of which board has failed let me know
Posted on May 01, 2010
electech_fl
  • 68 Answers
SOURCE: flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
Posted on May 19, 2010
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
73 mitsubishi dlp tv 73737 has sound but no picture with red light in frount
You need a new lamp. The red light means the lamp failed to turn on.
You can find cheap ones on ebay for about $40. If you go to best buy they will charge an arm and a leg. You can change the lamp yourself and it will take less than 15 mins to do. The only tools youll need are a phillips screw driver and maybe a flat head.
Jan 26, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 73" wd-73740 no picture or sound and red light on front
Could be power supply failure. The red light only indicates power is getting to the TV.
Jan 09, 2014 | Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
I heard a popping sound in my tv, then it shut off. I turned it back on with no picture, then the green light went off and the red light came on. Is it the lamp?
yes , the lamp went out , u can get a shipone over the internet or buy the original from mitsubishi , i recomment the mitsubishi
Aug 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Great sound no picture
lamp needs to be replaced.
Apr 16, 2009 | Mitsubishi WD-73833 73" HDTV
Televison & Video Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
