REstoring ipod won't let me Restore keeps saying
6ya staff
SOURCE:
cropp
Irwan Darmawan
  • 377 Answers
SOURCE: Restoring Ipod issue
hi dear
Following is list of iPod and iTunes Error messages or Alert messages you may come across while trying to open or install iTunes, update, sync or restore iPod, making a purchase from iTunes Store, or perform any other activity in your iPod/iTunes:
  1. "Unable to Check for Purchased Music because an error occurred (-5000 error)."
  2. "Error (-35)"
  3. "There was an error in the iTunes Store. Please try again later."
  4. "-5000" and "-35"
  5. “Error 1415” “Error 208” “Error 1418” “Error 1413” “Error 1427” “Error 200” “Error 1402” “Error 50” “Error 1406” “Error 1407” “Error 1428” “Error 1417” “Error 60” “Error 42” “Error 48” “Error 39” “Error 1417” “Error 53” “Error 69” “Error 50” “Error 3221””Error 2738” “Error1921” “Error 1607” “Error 5000” “Error 9006” “Error 9800” “Error 9814” “Error 9815”
  6. "Failed to locate Supported File Types or There Are No Photos Found on this Device"
  7. "the iPod ** cannot be updated, the required folder cannot be found"
  8. "Cannot connect to the iTunes Store. An unknown error has occurred”
  9. “Disk is locked”
  10. "iTunes folder cannot be found"
  11. “Disk cannot be read from or written to”
  12. “Firmware update failure”
  13. “Drive not formatted”
  14. "The iPod "username's iPod cannot be updated. The required folder cannot be found"
  15. "Folder cannot be found or created"
  16. “Attempting to copy to the disk [iPod name] failed. The disk could not be read from or written to.”
  17. "Sync failed: unknown error (-124)"
  18. "iPod cannot be synced: required folder cannot be found"
  19. “iPod Service Error”
  20. Cannot Import to Itunes - error 2002”
  21. "Attempting to copy to the disk (iPod name) failed. The disk could not be read from or written to"
  22. “The iPod "Customer's iPod" could not be restored. An unknown error occurred (1418)”
  23. "The iPod "Customer's iPod" cannot be updated. An unknown error occurred (-50)"
  24. “iTunesSetup.exe is not a "valid Win32 application"
  25. "Internal manager error”
  26. “iTunes 7.02 not a valid Win32 application”
  27. "itunes.exe - Corrupt File"
  28. "An Unknown Error occurred (-39)"
  29. "Could not complete your iTunes Store request. The store may be busy. Check your Internet connection or try again later."
  30. "There was an error downloading your purchased music. An unknown error occurred (-50)."
  31. "-9800, -9815, -9814"
  32. "Unable to Check for Purchased Music because an error occurred (-5000 error)."
  33. "There was an error in the iTunes Store. Please try again later."
If you come across any one of the above Error or Alert messages, then either your iPod/iTunes has gone corrupted and your iPod may be in for a crash or maybe you’re already facing an iPod crash. iPod might crash or get corrupt due to any of the reasons from hardware failure to corrupt iPod cache to damaged Files or to damaged disk structure.
You must be cautious and try to recover lost data from your iPod from reliable and proved software which is non-destructive and can recover all data—damaged or deleted. Any compromise can thwart your recovery process. Try Stellar Phoenix iPod Recovery Software.
from this site
http://www.ipoddatarecovery.net/download-ipod-recovery-software.php
oke
Posted on Mar 22, 2008
Anonymous
SOURCE: 80g 5th generation ipod - Keeps restoring but wont fix anything
I had the same problem. The hard drive was bad. I replaced it and it is good as new. It is a Toshiba HDD. Good luck
Posted on Jul 14, 2008
clark_styx
clark styx valencia
  • 282 Answers
SOURCE: iPod says Use iTunes to restore
try to uninstall and reinstall itunes and try to connect your ipod again and restore
Posted on Jul 31, 2008
Nagendra Baliga
  • 96 Answers
SOURCE: APPLE IPOD 30GB
Hi all, Not to worry, Will provide the TS steps...
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Then follow these steps as well
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Then follow this step as well:
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Feb 06, 2009
Nomodo4u
Poppy Chulo
  • 863 Answers
SOURCE: restoring an ipod
Make sure you got the latest itunes version and latest ipod classic version.  Also you need to be on the original computer you used to sync with the ipod.  Open up itunes and connect the ipod.  Your ipod should show up on the computer.  Just click on the restore itunes back to factory default button and you should be g to g.
Posted on Nov 05, 2009
On the ipod touch the itunes icon comes out and is a usb cable with an arow pointing to the itunes icon
This will get your ipod working again through a restoring process:
Connect your ipod touch to your computer and make sure itunes is open. Hold down the power and home button for 10 seconds. After 10 seconds only release the power button and keep holding the home button until your itunes says it found an ipod in recovery mode. Then restore your ipod by clicking restore on itunes, or restore to a backup you might have made.
Hope this helps!
Please rate and vote for me if this works out!
Apr 20, 2011 | Apple iPod touch
If i hold the home button then press the off
That's not the right way to put your iPod touch to restore (DFU) mode. And to make it even worse, there is NO WAY of restoring your iPod touch without wiping everything out of it. Restore will always remove all data from your device.
The only possible way of keeping everything in your iPod is to remember the passcode. Yes, that's the only way, because iTunes (from your computer) won't even recognize your iPod, so you have no way of creating a back-up.
Now, if remembering your passcode seems impossible, and you still wanna be able to use your iPod touch again, you should forget about all the data in it and restore it while in DFU (restore) mode.
To put your iPod to DFU mode, plug your iPod to the computer. It doesn't matter if your iPod is not recognized by iTunes, just plug it in.
For the complete instructions on how to put your iPod/iPhone to DFU mode, click here.
And for more iPod touch / iPhone tips, click here.
Feb 09, 2010 | Apple iPod touch
I forgot the password to my ipod touch
There is only one way, you must restore the ipod which wipes out everything if you forgot it.
Updating and Restoring iPod touch Software
You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch.
• If you update, the iPod touch software is updated. Your downloaded applications, settings, and data aren’t affected.
Note: In some cases, an update may also include restoring iPod touch.
• If you restore, the latest version of iPod touch software is reinstalled, settings are restored to their defaults, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. If you’ve backed up iPod touch with iTunes on your computer, you can restore data from the backup at the end of the restore process.
Deleted data is no longer accessible via the iPod touch user interface, but isn’t erased from your iPod touch. For information about erasing all content and settings, see “Resetting iPod touch” on page 122.
Update or restore iPod touch:
1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2 Connect iPod touch to your computer.
3 Select iPod touch in the iTunes sidebar and click the Summary tab.
4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available.
5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
For more information about updating and restoring iPod touch software, go
Feb 06, 2010 | Apple iPod touch
Restoring an ipod
Nov 05, 2009 | Apple iPod classic MP3 Player
My ipod classic 80 gb wont restore and keeps clicking
Listen to the iPod when it is connected to the computer. Do you hear repetitive clicking sounds from the hard drive? If so, your hard drive is broken. It's not too hard to replace the hard drive yourself. Here is an iPod Repair Guide that shows how to open an iPod. Parts are easily available on Ebay. If you want somebody else to do it for you go to iPad Repair
Oct 01, 2009 | Apple iPod MA446LL/A MP3 Player
8 gig ipod songs are cleared, but they are still taking up space
Sometimes you need to restore the iPod even though you've already deleted the content. Below I have posted a step by step for restoring your iPod touch in iTunes. If you are still unable to sync the iPod after restoring please do let me know :)
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
May 14, 2009 | Apple iPod touch
My i touch says it is connected to the network but when i try to bring up the internet or maps or stocks or weateher it say it is not connected to the internet..?? what do i do?
Have you tried a restore to resolve this issue? Below is a step by step on restoring ipod touch and iphone.
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPhone or iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Whenever you restore your iPhone or iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPhone or iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPhone or iPod touch to your computer. Select your iPhone or iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option (as seen in the image below). If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your phone).
Once the restore process has completed the iPhone or iPod touch restarts and displays the Apple logo while starting up
Apr 26, 2009 | Apple iPod touch
Less Memory than my Ipod is Supposed to Have
You should start by restoring the iPod Nano and iPod touch using iTunes. Below is a step by step for both. This should resolve sync and capacity issues. If for some reason you have any further issues with these iPod's or this particular issue, please do let me know. I am eager to be of assistance :)
--------------------------------------------------- Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
How to restore iPod with click wheel (ARTICLE NUMBER HT1339)
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
Apr 22, 2009 | Apple iPod touch
Aahhh
Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Sep 08, 2008 | Apple iPod nano
IPod says Use iTunes to restore
Jul 31, 2008 | Apple iPod nano
29 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
