Use divx codecs ....free to download....divx player .....else
you can google search free codecs...ok
You may come across the problem that your DVD won't play on Windows 10 when you insert your disc into the disc drive. The causes of this problem can be that your Windows 10 does not have a proper DVD playback software, or something is wrong with your CD/DVD drive. It's not just you. It is surprising but for some unknown reason, Microsoft decided to remove the default media center support from Windows 8 back in the day and this has followed into Windows 10 as well. And today, we will discuss two ways to play DVD in Windows smoothly.
When you meet the problem of Windows Media Player won't play DVD, this is because Windows has dropped its support to provide Windows Media Player's built-in DVD codec for Windows 10 and above. You can try Leawo Blu-ray Player to play DVD.
google, VLC
posted 1000000 times this free app.
no MEDIA told at all in hand, my guess is its DVD-R (recordable media)
if your DVD ray does not show DVD-RW on the front then it can not play DVD-R, so upgrade that drive.
the tray front show what the drive can do beyond CD. look there first or remove the whole drive read
the label, Acer used like 10 drives in this PC as an OPTION new. only looking finds this fact.
OR run HWINFO32.exe for free (safe and free)
then on left pane. click drives
see your drive there, skip past HDD and see DVD drive, then click that on right pane is read and writes rules.
if it does what you want, the VLC will work.https://www.videolan.org/vlc/
HWINFO32.https://www.hwinfo.com/download/
this post answers both HW and the SW questions for failure.
the pc must be connected to the internet for PnP plug and play can work (for any drive installed now)
Acer TravelMate 2410 old core2 16 years old today, 2005 made relic.
running XP op sys the virus magnet and XP THAT FLAT HATES DVD DRIVES.
1: THE pC MUST HAVE A DVD DRIVE INSIDE FIRST.
2: THE pc MUST HAVE dVD drive and not cd only, AND MUST NOT BE BAD 16 YEAR OLD
THE DRIVE TRAY MUST BE MARKED DVD, NOT JUST CD .(a huge clue that)
3: THE DVD DRIVERS SOFTWARE LOADED . FROM ACER.
4: THE DVD DISK MUST BE FOR YOUR UNSTATED REGION.
5: THEN RUN VLC FREE APP AND IT RUNS.
REGION RULES PAGE 36 IN YOUR MANUAL STATES (and must be learned)
"Once your DVD drive is set to a region code, it will
play DVD disks of that region only. You can set the region code a
maximum of five times (including the first time), after which the
last region code set will remain permanent."
THE CORRECT DRIVE DAY 1 NEW IS: ( MOST HAD THIS BEST I CAN TELL. 4244N DRIVE.
Acer Aspire 3610 Travelmate 2410 CD-RW DVD-ROM Optical Drive TS-L462 GCC-4244N
RUN This to play Dvd, a great free player app,
free and safe and only from makers web site. above, no where else.
