If the stop light on your Candy Alise 1400 RPM Washing Dryer is flashing all the time and will not start any program, you may need to reset the machine. To reset the machine, unplug the power cord from the wall outlet and wait for at least 30 seconds. Then plug the power cord back in and press the start button. This should reset the machine and allow you to start a program.
The E22 error code on your Candy Condenser Tumble Dryer model GVS C9DCG-80 31100907 indicates a problem with the drainage system. This could be caused by a few different things:
Blocked drain pump: The drain pump may be clogged with lint or debris, preventing it from properly draining the water from the dryer. Check the drain pump and make sure it is not blocked.
Drain hose: The drain hose that carries the water from the dryer to the drain may be clogged or kinked. Check the drain hose to make sure that it is not blocked or kinked.
Drain filter: Make sure that the drain filter is clean and not clogged.
Control board: The control board manages the dryer's functions and if it's faulty it can cause the E22 error.
To reset the error code E22 on your model, unfortunately, it seems that your model doesn't have a reset button or an option button to reset it. The best course of action would be to contact the manufacturer or an authorized technician for further assistance on how to reset the code and troubleshoot the problem. They will be able to diagnose the problem and provide you with a solution.
8. Keylock This function allows to block unwanted changes of the set options on the bezel , during drying phase. Activation/Inactivation: Push 4 and 5 buttons simultaneously for two seconds . The sign "LOC" appears on the display. Unlocking the option, on the display appears the sign "Unl", only once. In case of opening of 'porthole' with activated key lock, the cycle stops but the lock is kept: to restart the cycle, you must remove the lock and restore Start. When the dryer is off, the option is automatically inactivated. Key lock can be modified at any time of the cycle.
Hi i have my dryer for under 12 mouths it all works comes on for a bit then starts to bleeping and it says e15 and then cuts out does the dryer have a rest button on it thanks
Using only the information I read, it sounds like the drum is not turning.
This might be from a broken drive belt.
It could also be from an overheated thermostat and/or a blown internal fuse.
Have a mechanic or technician take the machine apart and find out the problem
God bless your efforts.
i'm guessing a bit but the part that was reset was probably a resetteble thermostat on top of the dryer air manifold. take top off machine and you will see stats mounted on top of the air duct. one or more will have a little buttonin the middle. press this button and you will hear a slight click and the dryer will then work. however, if the problem is reoccuring, then there is probably a lint blockage in the air duct causing poor air flow
Hi I am having the same problems, the filter light came on so I cleaned the filter and condenser, but the light won't go off, the dryer works fine other than that, exept theres no heat but the book says there won't be any heat untill the light goes off. any ideas thanks Christine
