Question about Android Cell Phones
Itouch air2 keeps connecting & disconnecting to android phone. When I set it up phone could find itouch but itouch didn't list my phone in device list
2 Suggested Answers
6ya staff
SOURCE:
Joesipaq
  • 8 Answers
SOURCE: I can't connect my Emerson Wireless Bluetooth to
with the bluetooth on, hold down the round button for about 8 to 10 seconds and the light will start to flash red and blue. That means the headset is in pairing mode. The pass key should be 0000 or 1234.
let me know if that works!
Thanks
Posted on Oct 29, 2013
My android phone was working great for the iinternet but the last week it keeps losing connection what is the problem
You case may vary with the type of the connection you are using, sometimes when you are connected to a weak signal internet connection it will disconnects automatically. Or maybe the device itself is malfunctioning.
Mar 18, 2015 | Android Cell Phones
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
You can try this and see if it works for you:
Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
  1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
  2. Under "Wireless & networks," touch Wi-Fi.
  3. Touch the Wi-Fi switch to turn it to the On position.
  4. You'll see a list of saved and available networks.
    • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
    • Your device will remember networks it connects to and automatically connect to them when in range.
    • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
  5. Touch a network name from the list of available networks to connect to it.
    • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
  6. Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Nov 11, 2014 | Tablets & eReaders
Bluetooth is paired. Works for about 1 day. Then will not connect again.
Did you try the "Device Discoverable in ___ secs?".In settings, Make device discoverable first then set the length of time. Android phone have this limited BT capability i think.
Nov 14, 2013 | Motorola Mobility L512bt Cordless Phone
My wifi stop working,i dont know why???
Solutions to Common Android WI-Fi ProblemsFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up. I usually fix their problem after few troubleshoots but today while I was fixing a problem on my device, I realized that it could happen to any one - even to my readers on Guiding Tech. Hence we are going to discuss four of the most common Android Wi-Fi problems and see the probable causes and solutions to them.
Android Cannot Scan a Wi-Fi Network Reason
There may be two reasons as to why your Android cannot scan a network automatically. The first reason may be that the network you are trying to connect to could be Ad-Hoc in nature. As most of the Android phones are not configured to work on Ad-Hoc networks but on access points, they don't scan them.
The second reason may be that the Wi-Fi network you are trying to connect to might be hidden for security reasons.
Solution
By default, Android does not support Ad-Hoc Wi-Fi network but many developers patch the wpa_supplicant file on Android in order for them to work. If you do a quick Google search you will be able to find if there's a fix available for your device but the fix can only be performed on a rooted phone. Furthermore, don't forget to back up your original wpa_supplicant file if at all your phones goes into foreclose or boot loops.
If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
Wi-Fi Keeps Disconnecting Frequently Reason
The most obvious reason for the problem may be with the Wi-Fi Sleep Policy which disconnects your Wi-Fi every time your Android goes to sleep to save your battery's juice.
Solution
To manage Wi-Fi Sleep Policy, open Advance Wi-Fi settings on Android and tap the option Keep Wi-Fi on during sleep. Here, check the option Always to enjoy an uninterrupted connectivity, but you will have to compensate it with your battery life.
If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
Obtaining IP Address Infinite Loop Reason
I don't know the exact reason behind this, but it might be a bug in Android. I have seen many people getting this problem, and it gets kind of annoying when the problem does not gets fixed even after restarting the device.
Solution
First of all, you must restart your Wi-Fi router and see if that helps. Many people say that resetting the phone to factory state works but that's not an appropriate solution. Wi-Fi Fixer is an amazing Android app that can help you here. The app resets your Wi-Fi system files (same as when you reinstall the Wi-Fi drivers in Windows, or you disable and enable the Wi-Fi adapter) and services and helps you to connect to the network and obtain the IP address.
Solutions to Common Android Wi-Fi Problems
Ads by Google
    wifi-router.pngFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up.
    Solution
    ad-network-manually.png If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
    Solution
    Ads by Google advanced-settings.pngkeep-wifi-on.png If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
    Solution
    wifi-fixer.png If you know the range of IP address the router is broadcasting, you may configure your Android to use static IP address while connecting to the network.
    Can't Connect to Internet using Wi-Fi Reasons
    There may be several reasons as to why you are not able to connect to the internet even when you are connected to the Wi-Fi. The reasons may be:
    • The router is not broadcasting internet services.
    • The IP address or the gateway is wrong.
    • Problem with the DNS settings.
    Solutions
    You may use another device to check if the router is actually broadcasting internet. Also you can configure the IP address, the gateway and DNS manually to connect as their might be problems with DHCP.
    Conclusion These are pretty much most of the Android problems one might encounter on his device and the probable solution one can try to fix the problem. I don't guarantee that you will fix the problem but it's a good start nonetheless. And most of the solutions should work actually.
Thanks .
Sep 03, 2013 | Cell Phones
Itouch can't see my network
Not that I am aware of , but you signal strength will degrade if all the devices are on and using at once. Also your ISP MAY "throttle" your service/signal with high data usage. That said, Your iTouch and xBox, in the setting , wireless, the iTouch should see the signal, Is the wireless turned on? It's discoverable? If your wirell has a Password, has a setup box on the iTouch asked for the password? Use the Manuals for the devices to troubleshoot connections.
Dec 26, 2012 | Toshiba WRC 1000 Wireless...
The number of devices that can be registered has been exceeded.
I have a partial fix, at least for my case...
Go to settings>> network>>home network setup>>remote device/rendered>>remote device list
And you can see a list of all the registered devices. Mine listed several old phones, I removed a couple devices and it allowed me to register a new one. Appears that the max is 5.
Mar 24, 2012 | Sony Media Remote for Android
I want driver USB DATA CABLE HTC MAGIC
  • Open the Device Manager, select the ADB Device and open the Details tab. Look for "Device Instance Id", it should be something like vid_0bb4&pid_0c0*.
    If your * is not 2, these instructions will probably solve your issue.
  • Disconnect your device and uninstall the two discovered devices (you can do it manually from the Device Manager).
  • Open with a text editor android-sdk-windows-1.5_r2\usb_driver\x86\android_usb.inf.
    Replace all the vid_0bb4&pid_0c02 occurrences with vid_0bb4&pid_0c0* (e.g. vid_0bb4&pid_0c03).
  • Connect your phone and when asked for driver choose to specify manually a path and select android-sdk-windows-1.5_r2\usb_driver\x86\.
  • If the installation is successful, to verify that all is ok execute android-sdk-windows-1.5_r2\tools\adb devices, your phone should be listed in the device table.
Mar 10, 2011 | Computers & Internet
MY BLUETOOTH ICON IS ON BUT WONT CONNECT TO MY OTHER PHONE KEEPS SAYING PASSCOE MISS MATCH, KEEPS GENERATING ITS OWN PASS NO
its because you cant connect iphones/itouches to other devices apart from apple devices thatv why it come up with tha
Jan 18, 2010 | Apple iPhone Smartphone
Cell Phones Logo
24 people viewed this question
Top Android Cell Phones Experts
john smith
Steve Sweetleaf
Steve Sweetleaf
Dakshinamurthy...
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
