Question about HP Office Equipment & Supplies
My HP 5200 printer does not print pictures when I send it. It prints 2 or three sentences and stops printing.
6ya staff
SOURCE:
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
ikechinedu
Nathaniel Iwuchukwu
  • 184 Answers
SOURCE: Hp printer will not print pictures.
Did you install the complete package that came with your printer? check to see what you installed and check if you can see the HP photosmart on your program file of HP. what model of HP printer are you using?
Posted on Mar 15, 2009
Anonymous
SOURCE: HP 1020 Issue
Maybe if you hold down the cycle button and let it run through a "test cycle" to receive a printer data sheet it might clear the internal buffer or whatever you call that short term memory these printers have. Let us know. JP
Posted on Mar 17, 2009
niquose
Niqui Itliong
  • 198 Answers
SOURCE: how i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
Posted on Jun 23, 2009
Anonymous
SOURCE: hp laserjet p1006 printing jobs gets struck in printing queue
Solved a similar problem by turning off the UAC (User Account Control) in Windows Vista and Windows 7 machines. Worked great without UAC on.
Posted on Apr 17, 2010
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
Good day i'm having a freezing problem with my printer if i send 10-100 prints it processes then prints half the job and then freezes with processing written on the screen please help!
Dear Sinclair
The freezing occurs due to two things.
1- when you command print file size is more than the buffer RAM of the printer. ( it will solved choosing page no. selection to print). If there is option to increase the RAM of printer, may be up graded.
2- Fixing temp. when exceeds predetermined temp. it takes a short time may be neglected.
Thanks.
Mar 18, 2015 | HP LaserJet 5200 Printer
Hp deskjet 5550 printing only a few lines per page
The printer driver is corrupt. Uninstall it from the computer before trying to reinstall the driver. If you don't have the driver CD you can go to HP's website and download it.
Jan 12, 2018 | HP DeskJet 5550 InkJet Printer
Cannot print legal paper in HP laserjet 5200
Try to set in printer setting.
Select Printer-->Properties-->Advanced-->Printing Preferences-->Paper/Quality
Set it A4 Paper...
Jun 08, 2012 | HP LaserJet 5200 Printer
My HP 1315v psc is only printing the first half of the sentences. the last half is missing. It prints pictures ok, but not my letter I wrote. It's like I tore the letter in half and had only the left...
Mostly pictures are in color, if your color cartridge is good it will gives you good print,if your mono cartridge clogged you wont get proper mono prints.. remove mono cartridge take ear buds dip in to the water clean nozzles gently, take print out then chem repeat two three times if result not satisfied, replace mono cartridge..best of luck..
Sep 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
I just installed my new HP 1660 Printer that I bought last year. It has the following problems; 1. There are horizontal lines on the photo colored prints 2. When I print MS word files,...
This is the same problem. You need to run the cleaning cycle on the printer. Go to Control Panel > Printers > Select your Printer > Printer Properties > Maintenance > Clean Print Nozzles.
Please remember to vote for me if you like my solution.
Apr 07, 2011 | HP Office Equipment & Supplies
My HP 5200 printer prints very light as if its cartridge is low while its toner is full, this problem was present from the very first day i purchased it, changed toner cartridge but no effect, (meaning no...
Try changing you Print Quality Settings.
1. Go to your Printers and Faxes(XP), Printers(Vista), Devices and Printers(Win7) 2. Right Click on Your Printer Icon 3. Click on Printing Preferences 4. On Print Quality, Choose Best. 5. Under Features -- Check the box for Print in Maximum DPI.
I hope this helped a little :)
Feb 04, 2011 | HP LaserJet 5200 Printer
HP laserjet 5200 printer taking too much time to print a page..
HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
Try to send a test or a text page to calculate the difference.
Also bare in mind that first page takes longer to print due to printer heat-up procedure.
Nov 09, 2010 | HP LaserJet 5200 Printer
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Flashing three leds when I send print colour photography but no print photography only flashing
can print letters and such, but cannot print pictures. I have put in new ink . So why can't I print a picure. have never had this problem. All 3 lights start flashing.
Jun 07, 2009 | HP DeskJet 845c Printer
26 people viewed this question
Ekse
Thomas F. Schneider
