Depends on the HP of the motor. The long shaft will only ad a few lbs. See this link for motor specs on weights.
https://www.nadaguides.com/Boats/2005/mercury/outboard-motors
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
SOURCE: 2005 Mercury 50hp 2-stroke outboard motor very
The carberator is gravity fed and there is propbably gunk in it, when you give it more throttle, it needs more gas but can't get it. Then a build up of gas in the float bowl occurs and nothing works right. It has happened to me and its aggravating, do a complete rebuild on the carb or just replace it and you will be happier quicker.
Hope this helps, Coachtheune
SOURCE: Yamaha 115hp 2 stroke Outboard Boat Motor. Went
is it carbureted or fuel injected? are your warning horns working? if it iscarbureted then a few easy test can be done to find out. if its fuel injected then its a little harder but not impossible.(1) check compression. without the year model I'm giving you a average numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark fuel is the problem nine times out of ten. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under the engine coul. take it to the lake if no improvement. clean carbs. same test to be and fuel system service used of fuel injected engines. if no improvement in engine preformance then you will have to take it to a dealer to test with computer.
SOURCE: i need wiring diagram for boat 1993 Bayliner jazz
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
