Cars & Trucks Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the timing belt on a 2003 Tiburon
  • rdanunz Sep 16, 2009
    This does not show the timing belt replacment it shows the accessory belt replacement. I have the 4 cyl engine. Thanks anyway
ZJ Limited
Level 3:
  • Hyundai Master 17,989 Answers
  • Posted on Sep 15, 2009
ZJ Limited
Hyundai Master
Level 3:
Answers
17989
Questions
0
Helped
14448711
Points
60858
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle.
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. AccessorHow do I change the timing belt on a 2003 Tiburon - 3b0d2d5.jpgt routing-2.5L and 2.7L engines
3b0d2How do I change the timing belt on a 2003 Tiburon - 6470b70.jpgss=
Fig. Accessory drive belt routing-2.4L engines
Fig. AccHow do I change the timing belt on a 2003 Tiburon - 508cf9b.jpge belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt How do I change the timing belt on a 2003 Tiburon - 5cd1383.jpgL engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt rHow do I change the timing belt on a 2003 Tiburon - aa6cd2c.jpg engines
5cd1383.jpgHow do I change the timing belt on a 2003 Tiburon - 4081274.jpg>
Fig. Accessory drive belt routing-1.8L and 2.0L engines
Fig. Accessory drive belt routing-2.0L engines
I hope help you with this (remember rated this help) Good luck.
5 Related Answers
Anonymous
  • 11896 Answers
  • Posted on Feb 06, 2010
SOURCE: 03 hyundai tiburon serpentine belt change
You can go to autozone.com and register for free for free online repair manual for your vehicle. Also google images have pics. There are also more manuals here:
http://manualspace.com/manual/search/89-toyota-celica-gt-repair-manual-online-pdf.htm
jagjeffery
Jeffery Lewis
  • 329 Answers
  • Posted on May 30, 2009
SOURCE: 2003 Tiburon Timing Belt Replacement
the timing belt is not due to be changed until 120,000 miles i cant promise but you could make it to 150,000 but i wouldnt go much farther then that unless it wasnt changed at 60,000 if that is the case you are on barrowed time you need the belt changed as soon as possible.
Anonymous
  • 11 Answers
  • Posted on Aug 02, 2009
SOURCE: oil change, 2003 tiburon v6
Read all beffore starting. get all you need and get prepare beffore starting so you wont say any big word. Maybe have some safety glasses and never put youself on the way the oil would go out.
Buy yourself a 4.4L of new 10W30 motor oil, a oil filter, a little bucket of about 8" high and 24" round set of ratchett finaly some towel (for cleaning your tools and your hands if oiled by the old oil). Wait the motor to be cold. If you can, jack it a little bit just for you to be more comfortable under it. Better if you have ramp to put the front of the car on it and dont forget to put some safety like small candel and a tire stpper with the hand-brake on.
Go under the car, locate the oil pan and it's pug. Get the good size key or rattchet for the plug. Put you bucket under the plug, in line of the oil comming out, about 8 inches from the plug. Now unscrew the plug.... it will be a bit dirty and replace the buckey in line with the dirty oil if needed. When empty (about 10 minutes) get the oil cap on top of the motor out, go back under the car put the oil pan plug back (don't forget the washer and don't over tite it) , unscrew the old oil filter (watch for oil comming out from it also). With your finger, put some old oil on the rubber ring of the new oilf fliter and screw it in place of the old one "by hand", don't turn too hard, about half turn after the rubber touched the motor. Put the new oil in (where the oil cap on top-front of the motor was).. all the 4.4L. (watch for not putting oil all over, it will smell as hell when driving until it will all burn). Put the oil cap on. Recheck the filter, the oil pan plug and the oil cap. If all ok, Start the motor for 5 minutes but stay parked. Check the sound of the motor, it should go nicely ( by the way, get a full memory of this nice sound, it could alert you of somehting wrong if it dose not sound like this one day). Get you tools and the bucket from under the car, recheck the oil filter and the oil pan plug. If no oil is dripping, stop the car, get it down, get all things clear and clean. You can put the old oil in the can where was the new one beffore the job and get it back to your garage so they recycle it. The filter is gooing to the garbage. That's it. If not in a hurry and take your time with some good music and a coffee, you can do it in 20-45 minutes.
2-
Anonymous
  • 3 Answers
  • Posted on Sep 24, 2009
SOURCE: need manual to change timing belt in 2003 tiburon
Check with local junk yards or try on Ebay they have some manuals also.
Anonymous
  • 436 Answers
  • Posted on Jun 10, 2011
SOURCE: need timing belt diagram for
The timing belt diagrams are listed in detail with figures and procedure to remove them.
REPLACING TIMING BELT ON A 2003 HYUNDAI TIBURON 2.7L V6
1. Remove passenger side headlight via the 3 10mm screws holding it in place and disconnect the turn signal and main harness
2. Remove passenger side tire
3. Remove the splash guard via 2 10mm screws at the top of the guard
4. Remove the 2 17mm bolts and 2 17mm nuts from motor mount bar
5. You may have to separate the mount bar from the motor via either a chisel or flathead screwdriver and a hammer ( support engine via a jack and a piece of plywood under oil pan )
6. Use a 3/8 ratchet ( or a long breaker bar would work better ) to remove the serpentine belt ( remember the route ). Disconnect the power steering hose from the pump and secure back with a zip tie. Remove the power steering pulley with a pry bar and 19mm socket.
7. Hand turn the crankshaft via a 22mm socket to TDC ( top dead center, marked on lower timing belt cover )
8. Remove the serpentine belt tensioner via 2 12mm bolts on each side
9. Remove the upper timing belt cover via 7 10mm screws
10. Remove crankshaft pulley ( 22mm ) with an air impact gun ( an electric one will work too )
11. Remove lower timing belt cover via 4 more 10mm screws
12. Remove the motor mount from the block via 3 14mm bolts and 2 12mm bolts ( there is a 12mm holding the oil dipstick bracket towards the front of the car )
13. Remove the auto tensioner via 2 12mm bolts
14. Remove the timing belt
15. Make sure your timing markings are correct...
There is one marking on each cam gear and on the heads ( head markings are small, look closely...try wiping the edge of the head down with a rag and some brake cleaner to bring it out more ) They are also pictured in last pic.
When the crankshaft is in the TDC position, the cam gear markings should both line up at the same time with the head markings
Adjust if necessary, use a 17mm socket to turn cam gears to correct position
16. Install new timing belt ( as you install it, make sure to keep a little tension on the belt as you route it )
17. Install new auto tensioner and pull pin
18. Install just the lower timing belt cover
19. Install the crankshaft pulley
20. Hand turn the crankshaft atleast 5 times to verify the timing markings are lining up properly ( all should line up at the same time when the crankshaft pulley mark is in the TDC position )
21. Remove crankshaft pulley
22. Remove lower timing belt cover
23. Reverse steps 12 - 1
You can refer the videos below for further assistance.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
1helpful
I have a 2003 tiburon and I need to know if its a valuve clearence engine or not
are you asking if its a interference or NON INTERFERENCE MOTOR?? did you blow the timing belt off??
5helpful
2answers
4helpful
Need manual to change timing belt in 2003 tiburon - 6 cyl
2helpful
2003 Tiburon GT, RPM's drop way down and idles rough at stop's?
More maintenance history needed. Oil changed regularly, timing belt replaced at 60 K miles, Engine air filter & intake air hose inspection?
Causes of the problem you describe are many. Recommend you have a technician check your throttle position sensor for any bad spots in the potentiometer... most likely cause when there is NO Check Engine light.
1helpful
Problem with 2003 Tiburon water pump
its driven by the timing belt,it also has a plastic pulley that breaks away from the drive,silly idea but lots of cars use it
5helpful
Airbag light is on - 2003 Tiburon
section_closed.gif 2003 HYUNDAI TIBURON Recall ID from NHTSA: 02V290000 Auto Recall Date: NOV 05, 2002 Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Model Affected TIBURON Estimated Vehicles Affected: 7382 Recall Details Auto Recall Date: NOV 05, 2002
Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Estimated Vehicles Affected: 7382 Model Affected2003 HYUNDAI TIBURON
2003 Hyundai Tiburon Defect Summary:ON CERTAIN PASSENGER VEHICLES, THE DRIVER SEAT BELT BUCKLE WIRING COULD BE DAMAGED BY INTERFERENCE WITH THE DRIVER SEAT CUSHION HEIGHT ADJUSTER MECHANISM.
Defect Consequence:DAMAGED DRIVER SEAT BELT BUCKLE WIRING COULD CAUSE THE SEAT BELT WARNING LAMP OR THE SUPPLEMENTAL RESTRAINT SYSTEM (SRS) AIR BAG WIRING LAMP TO ILLUMINATE. IT COULD ALSO CAUSE THE AIR BAG FUSE (CAVITY NUMBER 5) TO OPEN, PREVENTING AIR BAG DEPLOYMENT. NONDEPLOYMENT OF AN SRS AIR BAG IN A CRASH WHERE AIR BAG DEPLOYMENT IS WARRANTED COULD INCREASE THE RISK OR SEVERITY OF INJURY IN A CRASH.
Remedy:DEALERS WILL INSTALL A NEW DRIVER SEAT BELT BUCKLE, IF NECESSARY, AND WILL PLACE A PROTECTIVE COVER OVER THE DRIVER SEAT BELT BUCKLE WIRING TO PREVENT DAMAGE FROM OCCURRING. OWNER NOTIFICATION BEGAN ON MARCH 24, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HYUNDAI AT 1-800-633-5151.
Notes: HYUNDAI MOTOR COMPANY 056
2answers
2003 hyundai tiburon 4cyl wont start
I know there is no imoblizer on canadian modles not shure about american if there is that would be my first thing to look for
other then that you have changed alot of parts but have u checked any of the fuses or relays and dubble check that every thing is plugged in correctly if all that is good u have a wirring problem
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
