Question about Craftsman Garden
Looking for an ignition switch for a noma dynamark riding mower model # E3912030. Bought used had a craftsman 4 position switch on it but no markings to identify part.mower serial number S002230331405
6ya staff
SOURCE:
Mr Kelly G
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
fittr
  • 32 Answers
SOURCE: I need the routing diagram for the belt on the
look under the running board most are on there
Posted on Jul 23, 2009
ih82bl82001
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Posted on Jun 01, 2010
wwwtou-rober
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Posted on Aug 23, 2010
Anthony Browning
  • 640 Answers
SOURCE: Noma/Dynamark/Riding Mower/M0del#E3912030
After the E-clip is removed and the washers slide off the wheel should slide off. This being a rear wheel it has to come straight off due to the key. Nothing else holds the wheel on. If it is not just sliding off, it is okay to use a little force to pull it off.
I hope this helps.
Posted on Jul 29, 2011
Dynamark / Noma riding mower Mod# A38120910, SER# 149606, Code 0025M. how to get rear tires off?
i change the tires with the wheel on the mower if they don't slide off with the bolt or clip removed
Jul 02, 2012 | Garden
How can I replace a lost ignition key for a Craftsman LT2000 riding mower
the model number is under the seat on a sticker most riding lawn mowers use the same key the older models used one the looks the same on t=both sides and was short the newer style is longer and has cuts on one side only most any lawn mower shops will have them
Jun 14, 2012 | Craftsman Garden
Noma/Dynamark/Riding Mower/M0del#E3912030 Ser#S001219331405 C0de1335 I w0uld like t0 ha ve a manual sh0wing parts and the way they are assembeled.Expl0ded veiw diagram w0rks als0.Trying t,o remove the...
I hope this helps.
Jul 29, 2011 | Mtd Garden
Electrical schematic
i need a diagram for the ignition switch on my craftsman mower
....7 prongs all labeled with letters sure what 3 are for not other 4
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a wiring diagram for the ignition switch on a model#917255691 sears riding mower Thanks for any help rcwebster72@hotmail.com Carlton Webster
Go to www.partsdirect.com. This is Sears website for equipment information. Put the model number in and it should find the model you are working on. A diagram should be available there.
Sep 25, 2009 | Craftsman Garden
Garden Logo
35 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
