AGPTEK MP3 player turned off during play and now won't turn back on. Have tried charging and resetting. Still won't work :(
6ya staff
SOURCE:
Anonymous
SOURCE: Sansa e200 MP3 Player tur on problems
hold the power button for 15 seconds
Posted on Mar 24, 2007
Anonymous
SOURCE: Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
Posted on May 10, 2008
Anonymous
SOURCE: barbie mp3 quit working
You have to change the battery. To do that you have to take that thing off on the back of the MP3 player and unscrew it to change the battery.
Posted on Jun 10, 2009
Anonymous
SOURCE: Samsung YP-K3 MP3 player will not turn on?
Hi.. just had the same problem a few minutes ago and found a solution posted by preciouss_me from the other link..so i tried it and it work. I did reset the button at the back and whoala! it turned on and no files have been deleted..i hope it works for you too. thanks!
Posted on Oct 28, 2009
Anonymous
  • 25 Answers
SOURCE: The power/menu button of my RCA M4304-A mp3 player
reset it 10 times constantly if doesnt work see your closest tech savy friend
Posted on Apr 22, 2010
My insignia sport MP3 player froze so i turned it off and now it won't turn on, i tried to charge it thinking it was low baterry but it doesn't charge either
I had the same problem. The reason is because you have not charged your player, in a while.
First of all, try this.
Reset the Insignia Pilot if it freezes during normal use. To reset the device, press and hold the "Power/Hold" switch to the right for approximately 10 seconds until the screen turns off. The "Power/Hold" switch is located on the top of the player.
If that does not work, you need to remove the battery and then put it back.
Here's how to do it.
https://www.youtube.com/watch?v=29ULLzZqHLI
Then plug your cable and wait until it comes back to life. Be patient, it may even take a couple of days, until a full charge is accomplished.
Jan 22, 2014 | Insignia Sport MP3 Player
My Philips GoGear MP3 won't turn on. Is there any way it can get fixed? I've tried resetting it but nothing happens.
(I "ASSUME" you charged it, or tried to). HOW OLD is your MP3 player??
If it's pushing 2yrs old, or played/used on a fairly regular/daily basis,
.....YOU MAY JUST NEED A NEW BATTERY.
Carefully peel up the UPC code strip on back of player. (There is a tiny screw underneath it)
Carefully remove screw. (The snap notches are 'L' shaped inside the edges of the case).
Gently slide/pry open the backside of the case, taking care NOT to break the snap notches.
Open case, REMOVE BATTERY. FIND/MATCH BATTERY TYPE. (look in WATCH batteries).
Place the new battery in player. Close case, restart/turn on player.
Nov 04, 2011 | Philips GOGEAR SA6045 MP3 Player
My dolphin inexplicably shuts off for no apparent reason. It's been happening since I charged it last - about 4 uses ago. It'll be playing for 5 to 10 minutes, even 15, then just shuts down. ...
Have you checked the settings? There's one in there for auto-shutoff. I had this happen and it turned out I had accidentally changed this setting.
Sep 12, 2011 | NuTech NU Dolphin (4 GB) MP3 Player
My Zen will not do anything,it's froze.
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
May 16, 2009 | Creative Labs Zen V MP3 Player
Wont turn on...
Try resetting the MP3 Player. Turn it on, connect to your computer, press and hold the play button for 10 seconds and disconnect from your computer. wait 5 seconds and connect back to your computer. When charging always leave the MP3 player in the on position.
Dec 31, 2007 | Audiophase MDP-1 Personal MiniDisc Player
"no file" message that won't go away
verify the files using your pc. try placing them on the root (no folders).
Sep 13, 2007 | Hyun Won mobiBLU DAH-1500i (2 GB) MP3...
My Sansa e250R, 2 gigs, froze. Help!
It seems like your E250R is experiencing a temporary system error due to a corrupted song, and needs to be reset. Try to "Soft Reset" your player, press and hold the "Menu" button until the LCD light and scroll wheel light turn off. Since the player was probably left on for more than 7 hours (as you indicated), you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours. Next, try to format the player to rid of any corruption then re-transfer the songs. If you have subscription songs, then I would suggest to delete the song you last played which caused the error. I hope this helps. There is another solution for the player, but for now this might actually resolve the issue. Let me know the results. :)
Apr 23, 2007 | SanDisk Sansa e250 MP3 Player
 Grubhead
Grubhead
Marvin
Marvin
