My print cartridges are in the printer but it will not print. Tri-color print cartridge is 75 and the black print cartridge is 74xl.
Are they new cartridges?
If so, have you removed the clear plastic protection strips from the cartridge heads?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Please try follow these steps to resolve your issue:
Are you using OEM, compatible or refilled ink cartridges? Refilled ink cartridges have a high defective rate, and they
may also damage your printer, so it is best to use high-quality print
cartridges. OEM and certain brands of compatible print cartridges (such as MSE
brand:
http://www.dependablesupplies.com/search.php?search_query=MSE&submit_search=Search)
are the best choices.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color. And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
not new cartridges
