SOURCE: dacor convection oven cps127/130 failure code f1
i found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
SOURCE: carrier ac unit
This appears to be a Roof Top packaged unit. You will definitely need some help with this install. Your local Carrier distributer should have the installation curb kits and economizer etc.
Here is the most technical data I can find for this unit. Under the 50TFF section you will see the accessory dimensions. I hope this helps. (You will need adobe acrobat to read the file)
SOURCE: GE JGBP85WEB5WW - F7 / E9 Error codes
Well first of all you determine if problem is with the Key Panel or Control by-
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
Hi Keith , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Model number
