SOURCE: 3000Z and Speedotron Flash power pack
I've used my Epson PhotoPC 3000Z with a Bowens studio flash unit with approximately a 15 ft. synch cord; and I've had no problems. I suspect a faulty connection somewhere.
SOURCE: epson 5500 projector
befor you go deeper:- clean lens-miror in optical system check with another vga cable.if it is fixed ok. if not pass it service center.
SOURCE: Power Cord
It requires a 20V power converter capable of supplying at least 1.6A. Any such converter with the proper sized plug should work, but Epson will tell you it will void the warranty
Check your DC Power Jack which is where the power cord plugs
into the computer is bad. Take an ink pen and push the tip inside the
jack and see if the little pin wiggles, if so the jack is bad. You'll have to
take the laptop apart to fix it. Most times it is soldered onto the
motherboard, so you will have to desolder the old and solder a new one.
