I tried removing it by pressing Cancel button and power button method. but once i turn it off it gives the same error. and also the the scan belt is no longer working.
SOURCE: washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
SOURCE: canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
SOURCE: Removing front bezel of Dell 1907FP monitor to repair stuck power button
ThndrChld's suggestions are great but way too complicated. all you need is a flat head screwdriver. the front bezel/frame/whateveryoucallit can be removed without taking the backside off at all.
the reason the power button gets "stuck" is because it is set off centered from the sensor on the chip underneath it and it relies on a little protruding arm to press down on the sensor...this arm has broken off. button is not really "stuck." its a stupid design flaw by dell or whoever they contracted to make the monitor.
take the screwdriver and just stick it into the seams along the side of the front frame (black frame) and wrench side to side, twist your wrist, etc, to open. you will hear creaking and cracking but thats ok and doesnt damage the monitor at all (though you may create scratches and dents in your casing), its just the clips and snap ins coming loose.
here is a shot of it opened. the chip is held in by 3 very small screws. there is nothing you can do about the power button being broken.
(see this pic shows only front frame is pried open, nothing else)
the way i circumvented this broken power button is to drill a hole directly through the bezel/frame to the chip itself. i turn on my monitor now with a toothpick (i dont suggest using a paper clip as i first did in this shot, it will scratch up the metal on the chip). you can see where the paper clip is inserted and shows that the sensor on the chip is offset from the power button.
do this or take it into a shop and pay money =). who cares about a nasty looking front bezel, at least my monitor still works.
SOURCE: i have the error code 5b00 on my canon i905d. please help
The error code can only be reset by using diagnostic routines only available to canon shops.
SOURCE: my printer canon mx308 alarm error 5b00 we can't
check canon website they can tell u what error code means
