Washing Machines Logo
Bruce Davis Posted on Sep 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lid lock will not engage on whirlpool clothes washer although there are no clothes or other objects preventing it from closing
David Gust
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Sep 24, 2019
David Gust
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
70153
Points
779
Generally speaking the lid lock works either electrically by a solenoid or on older models when the tub spins it creates a breeze and a blade blocks the lid.
5 Related Answers
Anonymous
  • 1028 Answers
  • Posted on Apr 27, 2008
SOURCE: The Lid Lock will not
bad lid lock most likly cause..clips under edge of top release top switch mounts to front edge of top and wires runs to control under console
Anonymous
  • 867 Answers
  • Posted on Sep 10, 2009
SOURCE: Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Anonymous
  • 572 Answers
  • Posted on Feb 06, 2010
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Anonymous
  • 15935 Answers
  • Posted on Sep 30, 2010
SOURCE: whirlpool duet washer ghw9250mw1 door won't close ...
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • Posted on May 07, 2013
SOURCE: my whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Lid switch was flashing on/off now won't even light washer fill and pumps out but won't wash or spin HELP
Maytag Maxima mhw1500dwo error code reads F5 E2. I replaced door lock but has buzzing sound and still does not operate. Need help please? Tony
The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction in the lid lock area.
Please check the lid lock area and remove any objects in that area. Also verify there are no clothing items in the way.
What does it mean when washing machine has F5 and E2 error
If it is a Whirlpool then The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction in the lid lock area.
Otherwise, provide the manufacturer name.
You may visit http://producthelp.whirlpool.com/Troubleshooting_Guides/Troubleshooting_for_Top_Load_HE_Washers_(Electronic_Control)/Error_Codes/F%23_E%23_or_F%23%23/F5_E2_Error_code_for_top_load_washers
1helpful
Kenmore 110.25852400 lid switch is sticking, inconsistently engaging. Is it possible to hotwire the switch connections to make it agitate?
You can bypass the lid switch and the only danger is if a small child or person opens the lid during high speed spin and actually try to reach in a grab something. How often does that happen. That is the only function of that switch, for safety at the time of the cycle.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
1helpful
Lid won't lock when going to wash.
Door Lock Failure
dL flashes if the following conditions occur:
extending.
attempting to lock.
Door Unlock Failure F-83
retracting.
unlocked state.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    Loses power in spin cycle
    First lid must be down before washer start spinning. Remove any obstructions in drain hose and or straighten drain hose to remove kinks. Lid or other object hit timer knob and turned the washer off - Make sure the Timer knob is pulled out.
    If the lid was opened with too much force when adding clothes, it may have hit the timer knob, pushing the knob in.
    If a laundry basket or other object hit the Timer knob, the Timer knob may have been pushed in shutting the washer off.
    Washer lid is not locked (Not on All Washers) - The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Use a flashlight to inspect the holes in tub for foreign objects like screws, nails, bra wires, etc. and remove if present.
    Du f flashes as code on whirlpooll whasher??
    Door Unlock Error
    If it is a cabrio:
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
