Hi Andrew D Souza, for what you say, your remote control has problems with the volume up key, try to disassemble it and clean the contact plate, with a little liquid clean glass, you will observe, as a accumulation of residue of rubber, on the contacts on the plate of the remote control, clean and dry very well
DO NOT USE ANY TYPE OF ALCOHOL
Let it dry very well, then assemble it again and see if it is solved
Comment the results
Regards Franco Dosil
Hola Andrew D Souza, por lo que comentas, tu control remoto tiene problemas en la tecla de subir volumen, prueba desarmarlo y limpia la placa de los contactos, con un poco de liquido limpia vidrios, vas a observar, como una acumulacion de residuo de goma, sobre los contactos en la plaqueta del control remoto, limpia y seca muy bien
NO USES NINGUN TIPO DE ALCOHOL
Dejalo secar muy bien, luego armalo nuevamente y prueba si se soluciono
Comenta los resultados
Saludos Franco Dosil
Testimonial: "Thanks Franco"
SOURCE: Where can I buy remote control for Yamaha DSP-3090
You can get a remote for this unit from here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DSPA3090&brand_pn=YAMAHA_DSPA3090&mode=large&uid=11819547734530
SOURCE: Yamaha DSP-A3090 7-Channel / Power + Volume Knob Problems
Well, found a unbelievable electronic repairman. He was not trained on the yamaha receiver but was very experienced in the field and said if I would pay $75 he would take a real look at it. He found the problem. It wasn't the power supply, it was quite simply two parts that had gone bad. It was the following parts, hopefully this will lead some others to the correct problem or atleast another idea to considcer when looking for the problem. First part was (2 each)
PN# LC75710NE, Price: $58.55 each, Second part was a Resistor, PN# R1.2W1.5, Price: $7.00. The receiver works like brand new.
If anyone wants to talk to this technician here is the contact info.
Universal Electronics, Phone# 251-414-3411 or
Fax# 251-414-3412
Thanks for all your previous help.
SOURCE: Yamaha DSP-A2070
Check the 'front mix' switch on the back, set it in off; main level on max.
SOURCE: Need 5 Digit Remote Code for a Panasonic Receiver HE-100
Try 1518 or 1039
/www.comcast.com/remotes/universal.html
SOURCE: Need code for yamaha ysp-4000 to program charter cable remote
Try 32471, can power on and off, change inputs, change volume, haven't found that I could do much else though.
