MY my600lmt UNIT IS IN DEMO MODE & i CANNOT GET IT OUT
I have the manual for your unit here:
https://www.manualslib.com/manual/823907/Navman-Ezy255lmt.html?page=62#manual
Demo mode can just be switched off by going to demo and selecting off
SOURCE: stereo stuck in demo mode
take your set to tech to repaired you set is having a memory problem that you cannot solve.good luck.greetings from belize.
SOURCE: how do i restore to factory settings?
I have researched Toshiba website. They do not list replacement system DVD/CD there. Did find a listing on Ebay but the item was sold. Checked the manual and there is no information on restoration within it. The result is that I do not see any easy answer for you. You could contact tech support @ Toshiba, generally pay for the call and requrest from them the restoration software. Or you could buy XP CD install the CD and acquire from online the drivers for the computer. Regret that the choices are not better.
SOURCE: I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
SOURCE: ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
reboot and hit the alt and f10 buttons at same time and follow the prompts
SOURCE: how do i take unit out of demo mode and set clock?
hold your sel. buton you use to get to bas, mid, and treble, and hole it down for a while till a new menu pops up. scroll using up/ down buttons till you see demo and left right changes the setting for it
1.Press the home button on the remote to go to the cross bar
2.Choose settings
3.Look For set up
4.Scroll down to factory setting and restore them.
5.After that it will go to set up mode when it asks home or shop/display select "home"
ok
