Question about Welding Tools
Zd48 incapable of clicking and lighting
My torch all of a sudden doesn't work. It'll click from the button (which easy slides up real nice) but no spark, no hiss no flame. It's brand new
    Sergeant:
  • 232 Answers
It sounds like a control board. See if you can make it work in manual mode
Posted on Sep 28, 2019
    Sergeant:
  • 181 Answers
Take it back it is defective.
Posted on Sep 24, 2019
Anonymous
SOURCE:
jumptrout51
steve
  • 3361 Answers
SOURCE: The electric spark lights the gas at the spark
Make sure the thermocouple from the gas valve is in the pilot flame. If it is and you have no ignition,replace the gas valve. The clicking stops once the oven ignites.
Posted on Aug 24, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My daughter spilled some water on the cooktop.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
jharvey572
Chris Harvey
  • 447 Answers
SOURCE: brand new machine red button doesn't depress- it feels springy but doesn't click therefore brush not working
if the previous solution does not work, as its new its under guaratee,and its also covered by the sale of goods act.so yake it back to where you bought it because its down to them to sort the problem out. best of luck.
Posted on Nov 14, 2011
richroth
Richard Roth
  • 9472 Answers
SOURCE: My burners won`t click to light
What is the complete model number of the unit?
Posted on Dec 16, 2012
Steve Papp
  • 1010 Answers
SOURCE: burners won't light on my frigidare 30" self cleaning oven...oven works but when i try to light burners i hear clicking but the flame doesn't come on
The clicking sound is from the ignition, but you do not have gas at the burner, I think it could be thermocouple.
Posted on Mar 21, 2013
How do I get the light on the iphone off?
If you are referring to the light at the side of the camera, this is the torch which you can turn off by sliding your finger up the centre off the screen from the bottom and you will see a menu like the one shown.
Click the left hand picture of the torch to turn it on and off.
Hope this helps...
Nov 06, 2015 | Apple iPhone Cell Phones
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How to make power point presentation
The PowerPoint software program allows you to create slide presentations that can be viewed on any computer.
While some graphic artists specialize in developing compelling presentations, anyone can develop a PowerPoint slide presentation that is attractive and readable.
Follow these steps to develop your own slide show.
Open your PowerPoint program. When the dialog box opens, click on the "Blank Presentation" option.
Choose an "AutoLayout" format.
Begin with the title slide layout, which is the first one on the left. Click "OK," and you will have a title slide to work with.
Add text to your slide by clicking in the title text box and typing a title.
Do the same thing in the subtitle box.
Create another slide by clicking the "New Slide" button on the Common Tasks toolbar.
When the AutoLayout dialog box appears, choose a layout for this slide.
Keep adding new slides until your presentation is complete.
Move from slide to slide by clicking the button on the lower-right corner of the PowerPoint window.
Clicking the button with the upward-pointing arrows will take you to the previous slide, and clicking the button with the downward-pointing arrows will take you to the next slide.
Save your presentation. Click the "File" menu and then click "Save As."
A dialog box will appear, and you'll be able to type in a name for your presentation.
The presentation will be saved to your hard drive.
as for the kreb cycle disgram im not sure
hope this helps
Oct 15, 2012 | Computers & Internet
I have a problem to download music.
As with much to do with the iPhone, there's a bit of a trick to getting this working smoothly so you can have control over your iPhone music, while keeping it as darn easy to work with as possible. The answer? Create a custom playlist for your iPhone music library.
Let me show you how to do it - it's pretty darn easy.
Pop into iTunes and choose File --> New Playlist. Now rename it to something logical: I use "iPhone Sync":
Now you can just drag and drop music from your iTunes library (in iTunes, needless to say) into this new playlist. When you're ready, you'll see a bunch of music happily ensconced in the playlist (remember, it's all just "pointers": the actual music files are still safely in the main music library, so if you delete something from a playlist , you haven't deleted the original music file itself):
At the bottom of the iTunes window it shows you how many songs are in the playlist, along with the size and total playing time.
At this point, you need to plug in your iPhone if you haven't already done so. It'll pop up the usual summary screen:
Now click on the "Music" tab and you'll see that you can select "sync playlist". Do that, then select the new iPhone sync playlist you've created
Set things up and that's all there is to it. Now click "Sync" in iTunes and it'll synchronize your playlist with the iPhone music library and next time you click on that ole' "iPod" button on the iPhone, your selections from you music library will be present.
Oh, and one really nice feature of creating this playlist is that you can manage it, adding and deleting songs to your heart's desire, even without your iPhone present. Whatever changes you make are instantly applied to your iPhone music library the very next time you synchronize the device. Suddenly even 8GB might feel small. :-)
Regards
Sep 10, 2011 | Apple iPhone 3G
How to make screen size smaller
Perhaps you mean... How to change screen resolution. Here's a quick way.
1. Minimize all applications 2. Mouse over to a part of the desktop that doesn't have any icons 3. Right click on the mouse
Depending on the version of Windows, you'll select Personalize, Display Settings, or something like that
4. Slide the resolution bar to something that you like. 5. Click Apply, OK, etc.
Jul 15, 2011 | HP Computers & Internet
How do I adjust screen brightness?
Hey there,
If your Notebook doesn't have a menu button or any sort of hard-wired option of adjusting to screen brightness, there are a couple of means to doing it in Windows.
First, if you have an NVIDIA card, you can go to the NVIDIA Control Panel in your Windows Control Panel. There should be an option in there that says Adjust Desktop Color Settings. You can increase the brightness from there.
If you don't have an NVIDIA Card, right click on the Desktop and goto Personalize. Click on Windows Color and Appearance, click on Show Color Mixer, then slide the brightness scale to make your screen brighter. Click okay and that should do it.
If you require and further assistance, post a reply to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch Senior Tech of LiveFix Support Services (LiveFix.net)
May 01, 2011 | Compaq Computers & Internet
How do i pair motorola h670 with blackberry torch
Please kindly follow the detailed solution provided below;
STEP 1 Put on the motorola h670 by pressing and holding the switch button for 5secs,afterwards you will hear a click followed by a blinking of blue lights,by now the headset is in pairing mode.
STEP 2 Activate the bluetooth radio on your blackberry torch,by clicking on the menu>set up>bluetooth>search.
STEP 3. After searching,your torch will find the motorola h670 in the list of found devices.click on it,afterwards a message will display saying "pairing complete".
By now your blackberry torch has been successfully paired with your motorola h670 headset and you are good to go.
Take care!
Dec 05, 2010 | RIM BlackBerry Torch Cell Phone
Just connected a HF 225 monitor to Vista Home 32 bit. No real manual; install CD does nothing. When I press the Menu or Brightness buttons on the monitor I get no response to keyboard or mouse clicks to...
They only include the Win7 driver on the CD. I'm surprised it doesn't work with Vista. Did you try going into the HF225_win7 directory and clicking on infinstallWIN7?
The monitor menu doesn't work with the keyboard. You have to press a combination of the three buttons to the left of the on-off button. It's not very intuitive.
Aug 08, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Welding Tools Logo
67 people viewed this question
Top Welding Tools Experts
David Soto
David Soto
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
