I want to get the right size because a friend used a dryer tubing on the back and I didn't see the hole myself and am sure using the right size will make a difference but I don't want to undo his tape job until I am sure..
SOURCE: engine size
Okay,
I love the 4.3L I have a tricked out 2000 S10 with that motor and its awesome(a few aftermarket bolt ons and those motors really scream!), I have also had an 89 Jimmy and 96 S10 with that motor so your in luck as I I know it inside and out.
The fuel pump is always a pain on trucks becasue you have to remove the tank to gain access. The pump is bolted in on the top side of the tank. I hope it doesn't have a full tank of gas as it needs to be drained(re-use when job is complete). Not to mention pulling a tank that's full of gas very heavy.
See this link for an overview:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008f213
Here's how you test the fuel pump relay, and fuel pump:
Fuel Pump
Also see figure 4 which is digram 3 from this link, this is the schematic on the fuel pump, the fuel pump's hot wire is tan with a white stripe, if you can test the voltage of this wire you can confirm it is not an electrical problem.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008f3ce
Also be sure to releive the fuel pressure before servicing
Let me know if any of this is jibberish to you and I can clarify further.
Good Luck again, and feel free to ask anymore questions.
SOURCE: i don t know how to use
hi mhead. What is the specific model of the said front carrier? However, you may check out the link I'm sending you.The said link might have a user's manual for your carrier.
http://www.tomy.co.uk/careline/product-instructions/nursery-product-instructions/
hope this helps..
-mox
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
SOURCE: Tape Drive Block Size
Bit of an odd one but i agree that block size could cause an issue.
Try this link for the HP tech manual for this drive.
http://www.tag.com/tech%20support/System%20Resources/Drivers%20&%20Utilities/Drivers/Current/7.2/HP%20DAT%20Storage%20Works/guides/unix.pdf
It may help with your issue and does detail block size changes on some systems.
SOURCE: kohler one-piece lowboy..rialto? leaks from suply below tank
No, tsolder is absolutly right about everything he says. I am not as daring as he is so I will be paying big $$ for the parts..
