GS72RFI Master Built.
SOURCE: Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
SOURCE: my freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
SOURCE: Refrigerator and Freezer not cooling....
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
SOURCE: Freezer & fridge works great for two weeks
its probably the defrost heating element located just below the evaporator coil,remove the evaporator cover and check the terminals on the element,then disconnect one wire off the element and check it for continuity
