This is where you can get the manual with the answer:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/spc250sf/spc250sfen.htm
SC400 cannot be cleared by the user. This is a fatal hardware error code. Call you dealer or repair company to get it fixed.
SOURCE: Service Call Message
SC 400 is a dirty toner mark sensor. Clean with alcohol, wiping with dry cloth causes static on sensor and attracts toner. Not sure where the sensor is, but look around transfer belt unit.
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
SOURCE: RICOH SP C222SF SC300ERROR WHAT IS IT. CAN IT BE
SC300 on a C222SF is a high voltage power error. You could reseating the connectors for the high voltage power supply and the engine board (EGB), but more than likely one of those two boards will need to be replaced.
SOURCE: me marca error sc400 una
hola tengo una maquina ricoh aficio mp c2030y me marca error sc400 Que es y como solucionarlo
gracias!!
