SOURCE: KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
SOURCE: sony kdl-40s2000 won't stay on and blink red 4 times
That error says backlight failure. It has to be troubleshooted to find out why.
SOURCE: Problem with Sony Bravia 46" TV (Model
blow out fan in mother board tower mother is over heating and not geting enough of air leting the mane chips over heating makes computer stop so it doesnt catch fire.
SOURCE: My new Sony KDL-52LX900 TV
Sony TV's have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
Broadcast Eng
SOURCE: Sony BRAVIA KDL-46V3000 Television goes black
This issue
is related to a power problem in as much as the TV turns off on it's
own. I think the TV has developed a power problem.
The problem is consistent with overheating on the power supply board of the TV.
The
power supply board of the TV has few capacitors and IC. If any of these
IC's gets short or become weak, it can cause the TV to turn off on it's
own.
When current passes from electric outlet to the power
supply board of TV. The current also goes to the weak/faulty part, then
the current stops or slow and the board overheats and TV shuts off on
it's own.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
This
is a common problem faced by many other users too. To solve this issue,
check the power supply board and read it with a meter and continuity
tester, in order to detect the faulty part and replace the faulty part
on the board which is short due to which power supply board.
Sony specifically uses GM1 Board. In other words, Sony power supply board is called "GM1 board"
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
You
can buy this part at any Fry's or Radioshack store or you can order
them online at vendors like "mcmelectronics.com"(look for electrolytic
capacitors). After replacing these capacitor (capacitors) most likely
the normal operation will be restored. Or you can buy a refurbished
complete GM1 power board from shopjimmy.com to save you some stress.
If
this task is too technical for you, you can call a family or friend who
has the ability to assist you (two heads are better than one).
