Panasonic sc-htb8 soundbar fails to pair with tx-fz802b
2 Suggested Answers
6ya staff
SOURCE:
mike0862
Mikey
  • 5746 Answers
SOURCE: Panasonic soundbar SC-HTB8 is paired to Bluetooth
If you have connected the optical cable then you should be able to select AV using the TV remote, keep pressing until you hear sound from soundbar!
Posted on Dec 28, 2014
I have low dialog and loud background noise on my panasonic sc-htb8 soundbar
That is a typical issue and not really fixable, it varies from video source to video source soundtracks.
Feb 21, 2017 | Panasonic Audio Players & Recorders
What is the difference between GPON B+ and C+ GPON transceiver?
B+ Module C+ Module Type One-fiber bi-directional optical module, class B+ One-fiber bi-directional optical module, class C+ Operating Wavelength Tx: 1490 nm
Rx: 1310 nm Tx: 1490 nm
Rx: 1310 nm Encapsulation Type SFP SFP Port Rate Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Minimum Output Optical Power 1.50 dBm 3.00 dBm Maximum Output Optical Power 5.00 dBm 7.00 dBm Maximum Receiver Sensitivity -28.00 dBm -32.00 dBm Optical Connector Type SC/PC SC/PC Optical Fiber Type Single-mode Single-mode Reach 20.00 km 20.00 km Overload Optical Power -8.0 dBm -12.0 dBm Extinction Ratio Huawei GPBD Board Thunder link com
Nov 02, 2016 | Computers & Internet
No power to the unit.
If you wish to get some details ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 27, 2016 | Panasonic SC-HTB8 2.0 Channel Soundbar...
Have bought a Panasonic soundbar SC-HTB8. No connection cable included. Which cable do we need to buy to connect Soundbar to tv please?
You will need an optical digital audio connection for the TV and the TV will have to be fitted with a compatible "optical digital audio" OUT connection.
The soundbar unit you have does not have an HDMI connection so you only have the one choice with cable..
Any electronics store selling cables will fit you with the correct one.
The one pictured here next to the HDMI cable is the type you need (aka Toslink) but if you don't have an Optical digital Audio Out connection on your TV you have a problem.
HDMI vs optical Which digital audio connection to use CNET
Dec 30, 2015 | Panasonic Televison & Video
Panasonic soundbar SC-HTB8 is paired to Bluetooth but won't play the sound from the connected TV, is there anything we can do. TheTV is a Panasonic smart tv & we have connected it with a optical lead
Dec 28, 2014 | Audio Players & Recorders
Sc 822 ricoh mpc4500
SC822 is a hard drive error. that machine has 2 installed and should be replaced as a pair. it's hard to determin which one has failed.
Jun 25, 2014 | Ricoh Aficio 1232C Color Copier
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
Your company has just moved to a new office building. The server has a fiber optic network adapter, but the building does not have fiber optic cables installed. How do you install a media converter?
100BaeFX to 100BaseTx media converter. ST to SC cable.
SCA connector goes to the RX port in media converter.
STA connector goes to the TX jack on network adapter.
SC male B to TX port on media converter.
ST male B connector to the RX jack on network adapter.
Connect media converter to network with Cat5e cable which uses RJ-45 connectors.
Jan 25, 2012 | Allied Telesyn Allied Telesis AT MC1004 -...
My speaker "B" channel has gone out. Is this an
Maybe I'm misunderstanding the problem...
One speaker? Why would you have one speaker attached to A or B? A and B represent speaker pairs and are driven by the same two amps.
It's also not clear if you're saying the speaker is failing or the channel. You CAN swap them to find out.
Either way, the amps are common to both speaker pair connections so if only the B pair isn't working at worst you have a switch problem.
Jul 01, 2011 | Onkyo TX-8511 Receiver
Radio wiring diagram.
The colours depend on whether you have a 4 speaker radio, or a 6 speaker radio.
4 Speaker radio:
ACC B+ Grey
BU+B Blue/yellow trace
TX + (Sat) Yellow
TX - (Sat) Black
Ground Brown
Lt RR Spkr Yellow and black pair
Rt RR Spkr White and Red pair
LF door Violet and Pink pair
RF door Bluie and Lt Green pair
Mar 10, 2009 | 2000 Toyota Sienna
29 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
