Mitsubishi WS-55511 55" Rear Projection Television Logo
Anonymous Posted on Sep 15, 2009
WS-55511 shuts off with in 1 secound when turned on.
Hello, I worked on this TV (mitsubishi WS-55511) today and you were 100% correct. After holding the bottoms for a while the led light started to blink indicating the error code as you mentioned. 2 blinks then a space and 2 blinks and space and 2 blinks and ,,,,,,,,. does that mean there is a short somewhere or bad STK?
Please let me know what I can do next.
Thank you so very much for all your help and time. Sunny
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Sep 15, 2009
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718378
Points
48227
See my reply to your last posting---The set needs The Stk-393-110 and whichever of the two pico fuses is blown replaced--I have instructions AND photos of what the fuses look like.
SD TECH
Testimonial: "VERY HELPFULL and very FAST responding. Extreemly happy with service. AAAA+++++"
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
tip
Reset Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
2helpful
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
tip
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
4helpful
2answers
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Power up
the error code will be a blink code from the led it should blink a couple times vbriefly pause and then blink again. Count the blinking led in between the slight pause.
1helpful
2answers
WS-55511
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
