Fuji MX-1700 Zoom Digital Camera Logo
Posted on Sep 15, 2009
Cannot get lens cover to open also no flash working
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Sep 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
6627
Points
36
Lens cover is easy to open. Two opposite side of lens cover can be press slightly and pull to opposite direction. Flash may not work for so many reason. primarily, low bat power, then bulb is busted or micro wire is lossen or no contact. lastly your circuit maybe not in perfect condition.
I have Sony VPL CS6 projector and the lens cover stays open and wont shut to cover the lens!! The Lens/Cover light on it flashes? It does project for about 15seconds or so but then goes off, this is when...
It is possible that there can be few reasons for the fault siad:
1.the lamp can be faulty
2. the filter can be clogged.
3. the lens cap trigger switch can be faulty and staying on
4.The power supply can be faulty, not delivering the power but shuts off.
5,the main processor board can be faulty witth errors.
It might need board swapping to confirm.
4helpful
The auto lens cover will not open on the canon FS100. Any ideas?? The battery is charged, and it worked this morning. Now it will not open.
I work for canon at one of there return centers. We get this problem on every model the only way to fix it is by replacing the front cover.
Unit turns on but no lamp
Sent to V3 SYSTEMS & SERVICES PTE LTD 64522679,
they are Projector Service Center in Singapore,
1helpful
Lens cover does not operate correctly
I fixed this problem on my Fuji FinePix A303 (though it took some hard work).
The problem:
Camera Lens Cover stuck open or stuck closed.
Power on, and get !LENS COVER error.
Lens fails to extend.
The solution:
Short answer: The motor driving the lens cover is weak and eventually breaks down. I manually open the cover now. This took a manual modification to the camera (and some work).
1. Take the camera apart. See here for details, and be careful around the flash, as you'll get a nasty shock otherwise! http://www.mathematik.uni-marburg.de/~haim/focuserr.htm
2. Once you can see this, you're just about there:
3. Take off the battery cover (in the picture above).
4. Wrap a wire around the sliding pin for the lens cover, and drill 2 small holes through the black structure underneath the battery case, and then to the outside. The wire goes from the pin to the outside via the two holes. You should be able to manually open and close the camera cover COMPLETELY now with the wire.
5. Reassemble the camera (actually, you can test that it's working when it's all apart, if you're careful).
6. To operate the camera now, close the shutter first while off. Power on the camera, and very soon after open the shutter all the way by pulling on the wire (from step 4). This basically mimics the action of the little lens cover motor. If you timed it right (you have about a second margin), the lens should extend and everything functions perfectly.
It would have been nice to have been able to simply buy a new motor, but that would probably be a pain and cost some money.
Hope this helps!
Matt Van Dyken.
http://mattvd.googlepages.com
Aug 16, 2008 • Cameras
2answers
Lens Cover Not Opening, Flash Only Occasionally working
my did the same thing.. until I got rid of my recharable batteries and got the ones for electronics
2answers
Flash icon
Same problem with the red flash icon. I can take a picture if I turn off the flash as well, but have to turn off the flash every time I open the lens. Have had the camera for 5 years and haven't had a problem. We needed to replace the lens cover recently and after we replaced the cover we started having this flash problem. It was working fine before the cover came off which leads me to believe we've changed our settings somehow....pleas
1helpful
4answers
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
1helpful
11answers
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
