Question about Samsung Dishwashers
Is there a recall for Samsung Dishwashers DW80K5050US. Ours stopped working. Hubby went to check/replace power cord and you could see that it had overheated badly at the power cord box.
  • 1,653 Answers
You should call samsung and report the problem. There may not be enough reports to merit a recall yet.
Posted on Sep 21, 2019
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Posted on Dec 01, 2007
Anonymous
  • 142 Answers
SOURCE: PTC153B50AM REPLACED POWER CORD ON RECALL
First off, you need to unplug power from the unit before handling anything on it, not just the master switch on the control board. There is still live power being fed to the unit while it is plugged in!
Now, the clicking sound you are hearing is a faulty relay on the control board. You have to replace the control board. The new ones are available from Amana/Goodman Mfg.. You will find, assuming you have more of these, your other units are going to start doing the same thing. It will be the same problem. When they send out the new control board, make sure you program the board. They no longer come pre programmed. It is actually a huge improvement on the older control board upgrades. Hope this helps, I have 140 of these in my hotel, I know them all too well. Let me know if you have any other questions and please rate this as a fix ya.
Posted on Apr 07, 2009
Mark Brooker
  • 18 Answers
SOURCE: Do indesit dishwashers have a reset button?
no they dont have a reset button you might be able to reset by holding the on button for 4 to 5 seconds
Posted on Aug 11, 2010
Laptop keyboard turning on but black screen
Laptop Computer powers on but display not working
Most likely solution for the following brands:
Acer, Asus, Aspire, Compaq, Dell, Fujitsu, Gateway, Hewlett Packard, HP, Lenovo, MSI, Panasonic, Samsung, Sony, Targus, Toshiba
1. Power off PC
2. Unplug power cord from PC
3. Remove battery
4. Hold down Power On key for 30 seconds.
5. Plug in power cord.
-DO NOT replace battery in your PC
6. Power on PC
Battery may be subject to recall due to fire hazard.
Google :'recall your laptop make and model'
Please return to share results to help others.
Thanks!
Jimm Harmon
Nov 22, 2012 | Computers & Internet
Maytag mdb 7100/7160 stopped working (control panel no responsive). i am planning to replace the electornic control panel. is that an easy "remove and replace" operation?
FYI: In case you didn't know there was a recall about 2 or 3 years back on the panel itself. If you didn't get yours replaced then I would try and see if you still have rights under the recall. If so, they will replace it for free.
I watched the repairman replace ours and it seemed quite simple as long as you connect the wires correctly. If I remember right he messed up the first time and had to go back in.
Jan 04, 2010 | Maytag MDB7100AWB Dishwasher
My ge profile dishwasher oveheated.
There was a recall on some GE dishwashers, but yours was purchased a bit before those affected. Just to be sure, go to http://www.geappliances.com/products/recall/dw07/ and input your full model and serial number (including the last letter of the serial number). Of the models affected by the recall, I've personally seen (and have photos of) one that burned, plus one that was close to it. Recalled ones can be updated for free, or if you decide to replace, qualify for a rebate toward a new GE dishwasher. (the recalled ones had problems with the wiring inside the door) If your model is not one affected by the recall, I would contact GE customer relations via their answer center phone (800-626-2005) to report this potential safety issue.
Feb 01, 2009 | GE Profile PDW9880NSS Stainless Steel...
We have a service contract with Broward Factory Service. My GE dishwaher went out with eater in it, no power. Checked the panel box flipped switch, nothing. The service tech. said the rinse aid cup leaked...
I was trying to find out if the dishwasher was on a recall list, and I did by calling GE direct. It was not, so the service I have is replacing the rinse aid box.
Thank you,
Aug 26, 2008 | GE Dishwashers
The unit will not power up. I tried using a different power cord to see if the old cord was bad. A small red light turned on for afew seconds, I heard some beeping, then the red light went out.
Take it back to the store you bought it from.
contact Samsung about this model. and politely demand a recall/file class action claim, or for the manufacturer to describe this model as a 1-3year disposable LCD TV
Oct 19, 2007 | Samsung LT-P227W 22 in. HD-Ready LCD...
Dishwashers Logo
90 people viewed this question
Top Samsung Dishwashers Experts
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
