Question about Ricoh Office Equipment & Supplies
My Ricoh mp2014ad is constantly front cover open when it is closed, how can I fix it
    Master:
  • 811 Answers
There is a sensor for that. Either a switch or an LED light sensor. Either something is broken causing the sensor to fail or it is a circuit board issue.
Posted on Sep 22, 2019
  • Anonymous Sep 22, 2019
    I recently replaced the USB module with another one which contains ethernet/USB interfaces. But an orange led permanently on. Is this have any effect with the issue??
  • Your Consultant Sep 23, 2019
    well, if it started the problem right after you put it in, then yes. If it ran for a while the started, no -- unless the reassembly messed up the switch alignment.
    The yellow LED is probably the LINK LED for the Ethernet I/O
6ya staff
SOURCE:
Paso Robles
SOURCE: Maytag Ice2O
I had the same problem 4/28/08 - Called Maytag they're sending the part and repairman free.
IN THE MEAN TIME.......Maytag suggested to me to: take a phillips head screw driver and remove the hinge cover from the top of the left door. You'll find a white connector with four wires coming from each side. Disconnect the connector in the middle and the flap will stop (and so will the lights).
Posted on Apr 30, 2008
Anonymous
SOURCE: display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
Posted on May 26, 2009
Anonymous
  • 175 Answers
SOURCE: close ADF cover 4732 on a Ricoh IS330DC. How do I
I'm not familiar with this model, but if it says to close df cover, then either the cover is not closing all the way, a plastic piece on the inside of the cover that actuates the switch or sensor is broken or the switch itself is out of position, dirty or broken. Good luck Colin
Posted on Jun 29, 2009
Anonymous
SOURCE: After replacing the housing. Front cover is closed
It is on the back side of the plastic white cover where the little display is locked in place you will see a tiny slot on the left bottom side.
Posted on Apr 07, 2010
Rafael Espinoza
  • 29 Answers
SOURCE: Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Posted on Dec 09, 2010
My machine Ricoh 700 power not on?
make sure all the compartments are closed fully and covers all closed.
Nov 20, 2014 | Ricoh Office Equipment & Supplies
How do i replace the toner bottle?
• 1: Open the front cover of the machine.
• 2: Pull the lever and open the green cover.
• 3: Gently pull out the toner cartridge.
• 4: Hold a new cartridge and shake it 10?12 times.
Note: ? Do not touch the "metal contact point" of the cartridge, or it may be damaged.
• 5: Insert the cartridge horizontally, and gently push it in completely.
• 6: Close the green cover.
• 7: Close the front cover of the machine.
Jun 20, 2011 | Ricoh Aficio 1232C Color Copier
Front cover open lite and symbol on, can't operate copier, but cover is actually closed
unplug it and take off the front cover, there are 2 interlock switches behind the cover with an actuator arm. Most likely the arm has somehow flipped behind the switches or possibly broke.
But that is whats happening, those switches are not being turned on.
Jun 03, 2011 | Ricoh Aficio 1018D Copier
Ricoh SPC400DN Getting frequent "Press A
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Mar 12, 2011 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
How do I replace a drum on a ricoh aficio 2228C
It very easy...:) if you have a drum in hand.
Open the front cover. Lift one big green handle. Untainted 2 big black screws and open the drum cover. There you will see four groups of drum+development unit. Pull out the needed drum and pull in the new one. Then close all covers and that's all
pifonski
Mar 01, 2011 | Ricoh Aficio 2228C Copier
Dec 03, 2010 | Ricoh Aficio 2035 Copier
How to reset toner on Ricoh Aficio 180
If you want to reset the toner bottle, open the front cover, lift up on the green toner handle, push the lever in to slide out the toner hopper, pull out the toner bottle, give it 1 or 2 gentle shakes, and put it back in the hopper. Then push the hopper closed until it snaps into place, push the handle back down, and close the front door.
May 25, 2010 | Ricoh Aficio 180 Laser Printer
Ricoh aficio cl7100 the error light comes on saying close duplex unit cover it is closed thanks Bill.
If you open the front cover, you will see a black handle / panel running diagonally, underneath the "green " transfer belt handle, and the drum /developer access panel...push in on this black handle /panel to re-seat it. That should do it.
Please rate me ;)
Apr 28, 2009 | Ricoh Office Equipment & Supplies
Ricoh ft5733 keeps on restarting
If I were you, I would call the service company back and have them come back and fix it for free... It would be a what is called a "RECALL" unless they informed you of another problem that may show up
Mar 13, 2009 | Ricoh 3310LE Copier
41 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
