Question about Locks & Locksmithing
Kaba 710 ii lock, needed to replace the batteries now when i put the new batteries in it makes the lock unlock noise but when i swipe the initialization card through the lock it flashes green then red
6ya staff
SOURCE:
Anonymous
SOURCE: humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Posted on Aug 18, 2008
Rammsteins
Toms Safranovs
  • 300 Answers
SOURCE: "Card Locked"
Hi!
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Posted on Sep 27, 2009
SOURCE: Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Posted on Oct 22, 2009
Testimonial: "Spot on. Thanks"
Anonymous
SOURCE: fuji s602z CF II card not initializing
I've bought a SanDisk ExtremeIII 4GB CFI card. Ofcourse, at the beginig nothing worked. Camera format command worked neither (initializing problem,...). I then formated my card through a car reader on fat16 and now everything works. Just make this command: format <volume>: /FS:FAT. After checking and formathing the card, you will be asked to go on by 64K size of cluster. say Yes.
Posted on Apr 02, 2010
Doug Holbrook
SOURCE: parrot bluetooth b250 xt alternating red and green flashing lights
While device is on hold both volume buttons for 6 seconds till you hear 2 tones. Then plug in factory supplied charger for 10 seconds. Unplug a d re-pair to your device
Posted on Nov 27, 2012
KARA ILCO FRONT DESK UNIT 780 SAYS READER ERROR OR INVALID CARD, CAN THIS BE CLEARED BY RESETTING?
We have 2 front desk units Kaba ilco 780A1, one of - Fixya
www.fixya.com/.../t4588452-2_front_desk_units_kaba_ilco_780a1_one
Apr 19, 2010 - Question about Simplex Kaba Ilco Unican 1000 keyless lock ... the grand master authorization card is swap it shows a message that says ''reader error or invalid keycard''. .... How to reset grand master keys front desk unit 780.
Hotel Lock - Front Desk Unit - Kaba
www.kaba.co.uk/68244/front-desk-unit.html
Kaba GroupMulti-track keycard encoding and reading; Drop and swipe reader track with ... Front Desk Unit brochures can be found on the Sales and Support page.
Dec 25, 2015 | Locks & Locksmithing
How do I upgrade an AMD Phenom II x3 710
I suspect you mean the Motherboard that has the AMD Phenom II x3 710.
If so then find specifications on that motherboard to see what better, faster? CPU is compatible with it.
4th Core is Disabled by AMD and you need to know how to enable it?
Maybe this can help.
Overclocking Phenom II x3 710 2 6GHz to 3 5GHz unlocking 4th core
Hope it helps
Oct 11, 2014 | AMD Computers & Internet
Nokia lumia 710 should be unlocked
Hello. What kind of unlock are you asking for your Nokia Lumia 710? If it is a network lock, you can visit TheUnlockSpot.com and get the accurate unlock code at affordable cost to get it unlocked. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia Lumia 710 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 710.
3 - Compose #pw+CODE+1#.
4 - The Nokia Lumia 710 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 710 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia Lumia 710
Sep 03, 2014 | Nokia Lumia 710 Smartphone Unlocked
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
1-800-849-8324 (option 1)
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
My kaba gun lock will not open i put new batteries in it i have tried 3 different one but nothing will work. i try to punch in my code and it just peeps at me and i can not get into m gun safe.
I don't have a direct answer, but Kaba customer service can be reached here:
Mar 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I was relocating a working Kaba m# LL101126D41 i had happen to turn the outside handle with the small key cylinder removed on the back side top now when all installed it wont lock . what do ineed to do...
Oct 13, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
63 people viewed this question
Top Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
