Question about HP Office Equipment & Supplies
HP T610 Error 21:13 but the motor moved !!
Hi, I had a problem too, 21:13 error on my T610. Once the Service Station is disassembled, it is clean and reassembled and all OK for a few weeks. Now the problem arises again and I thought it was that the engine struggles because the SS is blocked by interlocking or otherwise. Once everything has been connected with the dismantled Service Station advance motor and it starts a few turns during initialization, then stops and the display shows the error 21:13. Is it possible that the engine has become sluggish or that it does not detect the sensor, the round black one mounted on the all-drilled engine which tells the plotter that the engine is running?
6ya staff
SOURCE:
Anonymous
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Posted on Jun 27, 2008
Anonymous
  • 39 Answers
SOURCE: 2000 lexus es300 error code p0440, p0441, p0446
P0440 Evaporative Emission System, P0441 Evaporative Emission System Incorrect Purge Flow , AND P0446 Evaporative Emission System Vent Control Circuit
Posted on Apr 23, 2009
Anonymous
  • 64 Answers
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Posted on Jun 08, 2009
kevin duggan
  • 96 Answers
SOURCE: error 47:01 for hp desighjet t1100 plotter
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-167.
�� If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
Posted on Oct 01, 2009
Anonymous
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
Hi, I`ve recently posted a question about how to clean the waste ink reservoir. Waiting for the answer, finally I made the job and could clean it.Unfortunately, tto acces to the mentiones pad, you hav
this error indicates service station is not function properly, if you able to open the service station open and clean it re fix again 100% work.
other wise once you contact hp service center....
Dec 30, 2013 | HEWLETT-PACKARD Photosmart B209 InkJet...
Just got a new HP Designjet T770 hard disk printer, keep getting error code 21.1:03, turned power off and unplugged, still receiving same error code
Issue with the service station. Turn off and turn on your printer couple of times. Try moving the carriage assy., manually.
Still if it don't work then the service station would have gone bad. Needs to be replaced.
May 24, 2011 | HP Designjet T610 InkJet Printer
21.13
For tech guys only :Open right side door, check any obstruction in service station while moving.Check service station connection, re-fix once again.. checkRemove service station, remove motors, clean entire service station with water, ensure that entire ink should be washed out allow it for dry, apply grease to the moving parts, fix it back, check...( cleaning service station is very dirty work be prepare for that). check.. Replace service station...
Dec 02, 2010 | HP Designjet T1100ps Printer
Hp plotter T610 bacalhau. 21.1:03 Erro - troquei Estação de Serviço / APC e continua Dando o Mesmo Erro
The service station cannot move. Look for pieces of paper in there. Replace if broken. It's too dirty job to take apart the service station, to clean and find what is wrong with it.
Aug 05, 2010 | HP Designjet T610 InkJet Printer
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Power cord. Check the Primer Tubes. Reconnect the power cord and
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Jul 29, 2010 | HP Designjet T610 InkJet Printer
Mu HP Designjet T610 get mistake 21.13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Aug 05, 2009 | HP Designjet T610 InkJet Printer
HP T610 21:13 ERROR - THE SERVICE STATION DOESN'T MOVE ANYMORE IT'S JAMS
there can be three solutions to this problem. replace your service station, replace the print mech pca, replace the main pca in that order. hopefully you can get this on the first repair (service station). this can become expensive. let me know if this helps.
Jul 19, 2009 | HP Designjet T610 24-in printer InkJet
LEXMARK
That error indicates that you need to replace the Engine board. The part number is 11K1416, a service tech would need to replace it due to settings needing to be reset.
Jul 15, 2008 | Lexmark Optra T610 Laser Printer
Loud Noise
Craig,
My apologies for just now responding to this message; apparently my fixya mails have been getting caught by a filter and trashed without my seeing them.
I can think of a couple strong possibilities for this issue, and you're right; talking it through would be a good idea.
I will get in touch as you requested.
David
Apr 27, 2008 | HP Officejet 7130 All-In-One InkJet...
22 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
