Question about Dell Inspiron B120 Notebook
Battery light blinks twice and a few lights con on and then off
All lights are green but will not power up just a few blinks and thats it any idea
    President:
  • 2,030 Answers
Sounds like bad battery
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Sep 15, 2009
6ya staff
SOURCE:
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
Samsung has standby light, it blinks tone sounds no green light. Replaced t-con, power supply and control boards.
Hi Patrick,
have a close look at your LVDS cable and screen ribbons for signs of failure or heat damage, and you could try to pull a picture from an AV output in various formats to see if it's the screen itself is failing in some way,
regards
George
Jun 29, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
I GOT 14 BLINKING RED LIGHTS SONY BRAVIA KDL46VL160 I DISCONNECTED T-CON BOARD AND THE GREEN LIGHT STAY ON I ORDER USED T-CON BOARD TWICE INSTALLING AND AGAIN I GOT 14 BLINKING LIGHTS
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 23, 2016 | Televison & Video
Green power light on then standby light blinks twice over and over
hi
there is a problem in main board mean ip1so please replace the main board
Jan 06, 2016 | Sony KDL40S5100 40 in. HDTV LCD TV
Smartboard power light blinks twice, then no power.
first check the power of your system because if power is not working properly then light blinking.and then the condition of the capacitor on the board.
Dec 29, 2009 | Computers & Internet
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dell Inspiron B120 Notebook Logo
213 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
