Question about HP Office Equipment & Supplies
Sir, I have purchased one hp colour laserjet cp1215 model printer. how to solve engine error message
6ya staff
SOURCE:
dapidc
Dapid Candra
  • 118 Answers
SOURCE: hp colour laserjet 4600dn, 51.2Y error...how to solve that?
From Woody Friesen:
Did the printer have a rough ride? HP's service manual suggests this to be a laser error on the yellow laser scanner, though these printers usually withstand shipping without any problems. Just for grins, if you can get the printer to get to READY again, run the printer through a complete calibration (from the control panel: Configure Device/Print Quality/Calibrate Now). The DC controller circuit board is also a possibility, but given the error code popped up almost as soon as you plugged the machine in suggests the yellow scanner has suffered some sort of mechanical damage from the trip. If the calibrate routine doesn't remedy the problem and you want to be sure, you could do the major disassembly required and swap the yellow scanner with the scanner for another color in the printer and if the error code changes to 51.2M (magenta), 51.2C (cyan) or 51.2K (black) (the code will reflect which scanner you exchanged with the one in the yellow position) you'll have confirmed the scanner is the problem, or if no change, then the DC controller is next in the chain.
Posted on Dec 24, 2008
Anonymous
  • 14 Answers
SOURCE: hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
Posted on Jan 27, 2009
Anonymous
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
Big_Booo
SOURCE: My Printer HP 1600 Laserjet error 10.1001
Did you fix your problem? I have the same one. With Hp 2600N
All cartridge are new, and i removed the orange tab from each one.
I even tryed a second new cyan.
Did you remove All the orange tab from cartridge?
Posted on Feb 12, 2010
Anonymous
  • 75 Answers
SOURCE: my hp colourlaserjet printer (model : 3600)
if you go into the printer menu you will find that it can be set to calibrate at diffirent times. eg start up
Posted on May 10, 2010
What is the 59 co.error turn off turn on ? printer modle is hp 1215 colour laserjet pcl
I presume you are referring to the HP Model CP1215. The error 59.C0 error appears to refer to a mechanical error: Developer motor rotation error.
The recommended action is 1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize. 2. If the problem continues, contact HP Customer Support Center for technical assistance.
Your printer could be about 5 years old by now, so if this is a recurring problem you might be nearing the time for a replacement which might be less costly than taking your printer to be serviced.
You
Sep 09, 2014 | HP LaserJet CP1215 Color Printer
COLOR PRINTING PROBLEM
Have a look at your printer software settings. You may have it set to black and white only. There may also be a driver that was missed during installation to allow colour printing. Try reinstalling the software.
Dec 26, 2013 | HP LaserJet CP1215 Color Printer
Hp cp1215 fuser error
For most fuser errors if the documented troubleshooting doesn't work you will want to replace the fuser.
Feb 11, 2013 | HP LaserJet CP1215 Color Printer
Hp laserjet cp1215 only prints in black and white on windows 7 professional and during installation of the software brings a message to install disk 1.
HP CP1215 is compatible with Windows 7 (32-bit & 64-Bit)
All you have to do is download and install the CP1215 Drivers for Windows 7 (32-bit OR 64-Bit depending upon the edition you have on your PC).
Please visit the above link, Select the Operating System and download/ install the DRIVERS-PRODUCT INSTALLATION SOFTWARE.
Below is the Screen Shot of the Color Settings. Make adjustments as shown (Automatic):
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 27, 2011 | HP LaserJet CP1215 Color Printer
Sensor error
Sir
contact me at walid_sayed@hotmail.com and I will send you the service manual for free
regards
Apr 02, 2010 | HP Color LaserJet 2600n Printer
I have a brand new HP Colour Laserjet CP1215 printer purchased from PC World. I have an Apple iMac computer running MacOs10.5.5 When I attempted to install the new printer (to replace an HP Colour...
Not really a solution....this HP Colour Laserjet CP1215 printer works only in a Windows environment and is not compatible with Mac Os so I had to get another one and got pretty mad with PC World 'adviser' (?!)  who'd recommended the HP printer!!!
Dec 09, 2008 | HP Office Equipment & Supplies
15 people viewed this question
Ekse
Thomas F. Schneider
