Question about Hobart Welding Tools
Owners manuel hobart 187 mig welder power cord wiring diagram
How to connect the power supply to the welder
    Sergeant:
  • 232 Answers
There should be a diagram inside the machine.
Posted on Sep 28, 2019
  • Hobart Master
  • 10,638 Answers
6ya staff
SOURCE:
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
Anonymous
  • 37 Answers
SOURCE: Mig welder
Sometimes dirt builds up at the beginning of the liner, at the drive. Eventually the dirt jams in there so much that it gets very hard to push the wire through it. Carefully cut the wire between the spool and the drive and secure it to the spool through a hole, so it doesn't unspool into a bird nest, then disengage the drive roller, the wire should pull out of the tip freely. If you feel resistance when you pull it out, either there is dirt at the beginning of the liner, or the contact tip is causing resistance. Without the wire in the drive, turn on the machine and try it watching the drive. Does the drive work freely now? Does it change speed with the rheostat? If its a problem with dirt, this is what I do, after you get the wire threaded back through the drive, liner and contact tip, and everything is working, take a small clean cotton rag and simply tie it around the migwire between the spool and the drive, in a way that the drive can't **** it in. This will constantly clean any dust/dirt off the wire before it goes through your expensive drive and liner. Whenever you change the spool, change the rag. Hope this helps, and please post your results.
Posted on Feb 08, 2009
Anonymous
  • 7 Answers
SOURCE: wiring problem for a hobart G-213 welder
download it for free.
http://www.scribd.com/doc/12408431/1985-Wire-Diagram
Posted on Mar 21, 2009
Anonymous
  • 5 Answers
SOURCE: owners manual for a century wire feed 83160 mig
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Posted on Apr 30, 2009
97F350diesel
James Brooks
  • 1326 Answers
SOURCE: looking for an owners manual or wiring diagram for
You will need to contact Snap on. Will be $20-$25.
Posted on Sep 22, 2009
Hobart 187 mig welder. Gas flow is delayed shutting off and wire stays "HOT"until I hear it shut off in the welder cabinet. Never was like this before. I have had the welder for approx 10yrs.
take it in for a check of the relay for the wire that turns on the power when the trigger is pressed
that relay activates the gas solenoid and the power to weld
Jan 03, 2018 | Hobart Welding Tools
Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use...
the spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
Mar 11, 2011 | Hobart Handler 210 Wire Feed MIG Welder
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
Will 12-3 braided wire be ok to run 187 hobart mig at 75 feet long 30 amp breaker
I would run no smaller than 10-3, preferably 6-3. I've seen more than one welder burn out due to insufficient extension cords. 10-3 is pushing it for 75', and if you ever plan to extend the leads, you will be money ahead getting the 6-3.
Dec 15, 2009 | Hobart Welding Tools
I have a LINDE VI-252 cv/dc power supply and I want to hook up a Hobart 2210 wire feed and I need to know which pins on the back of the power supply to hook to.
you will have to get the user manual for mig welder stores for the exact connections of the wires.
click thois link directly to get the hobart user manual.its not the exact model but near to your model of hobart the connections will be near to same and will give fair idea to connect the parts
http://safemanuals.com/reference-HOBART/1
thanks.keep updated.
Dec 05, 2009 | Hobart Welding Tools
Need manual for Hobart 500416
Hobart has a wonderful site. Go to hobartwelders.com click on service/products and then manuals.
Paul
Mar 18, 2009 | Hobart Handler 140 Mig Welder
Have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
Feb 28, 2009 | Hobart Welding Tools
Welding Tools Logo
101 people viewed this question
Top Hobart Welding Tools Experts
David Soto
David Soto
John Ziehm
John Ziehm
rjivaro
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
