This could be a problem with the scanning assembly (Lamp or CCD board). I would try turning the machine off for 5 minutes and then turning the machine back on. Also make sure the scanner is not locked. If this doesn't work you would have to replace those parts.
Not at all certain what your question refers to. The Hp Image Runner 400 is a black & white copier. What do you want to do that you are unable to do? Have you previously been able to do what you wanted with this copier, but can no longer do the same? What happens when you try to copy a document? Does the copy come out blank, or all black? Are you getting a large black area on a 8.5 x 11 inch sheet of copy paper when you attempt to copy something that is smaller in size, and therefore wasting lots of toner? Please explain your problem in detail, or no one will be able to help you. Thanks
if its just copies clean the small glass to the left of the large glass its called the slit glass and is usally about 12 inches long and 2 inches wide if it comes out on prints as well as copies its a drum or fuser check to see which is bad another way to test if its the slit glass make a copie from the large glass if no line its definatly the sit glass
Black Print Speed:---------
15 ppm*****
Total Media Capacity:----
250 Sheets******
Max Resolution (BW):----
600 x 600 dpi*********
Being laser-based, the SCX-4100 is a more economical choice over bubble jet printer whose cartridges are expensive in comparison to their durability. But be mindful that the SCX-4100 is a black-and-white device – so no color printing/copying for you, although it obviously scans color documents. The toner cartridge is good for about 3,000 copies, a figure that can increase 40% with toner management software (included). The device has a main paper tray that holds 250 sheets up to legal size. You can manually feed a sheet at time into a slot right above the front paper tray, and there’s also a rear slot for jam-prone material, like envelopes and transparencies. Unfortunately, the SCX-4100 lacks an automatic document feeder. Thanks. you can rate this solution and show your appreciation.
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty. Does this happen when, Using the Doc Feeder When making copies from the Glass Or when you print from a computer (assuming you print from a PC) If you print something and this happens then it is inside the machine Probably toner or developer dumping... Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment... One more test If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
