Computers & Internet Logo
z
zeray zemedikun Posted on Sep 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I format my hp laptop it show that error code 0*000021a
goneforever.
Level 3:
Top Expert:
  • HP Master 14,531 Answers
  • Posted on Sep 19, 2019
goneforever.
HP Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263866
Points
66315
NO PC stated, no OS stated windows something?
hp.com the answer is there.
you meant? blue screen of ***** BSOD. (or?)
0xc000021a (means OS is corrupted !)
if the PC is still good and HDD not bad ,we test HDD first. if bad, BSODS forever.
The PC hard drive is still good. use the F11 key at power on
this is the HP official recovery mode.
F11 is HP windows re=install mode.
why are you formatting, and if yes, how?
My hp mini 2140 laptop says non disk or disk error hoe do I fix it
You must try to format it with a disk installer (windows cd).. During the process of formatting it will show the HDD is exit or not. If it not exist means the HDD is physically damaged. Or you will be ask for the partition to install windows on it
Hp 6930p nmi channel check iochk
System I/O address specifications 970-071 NMI enable/RTC
What is Nmi Error On Hp Server error? The Nmi Error On Hp is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
This code is used by the vendor to identify the error caused. This Nmi Error On Hp Server error code has a numeric error number and a technical description. In some cases the error may have more parameters in Nmi Error On Hp Server format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
What causes Nmi Error On Hp Server error? The Nmi Error On Hp may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Nmi Error On Hp Server error? There are two (2) ways to fix Nmi Error On Hp
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Nmi Error On Hp Server) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Hi i want to format my compaq dq61 when i format my laptot it show me a blue screen error
You have to tell me whats the error code it shows on the blue screen so that I can help you resolve your problem.
Boot mgr is missing and error code 0xe0ef000e after a fail recovery disc attempt, for a hp pavilion.
0XE0EF000E is an error message and means that the boot sector is corrupt or missing.
Re format the hard drive is the easiest way to recover and then restore your data backups.
Place your Windows install disk in the dvd drive and boot up the laptop. Follow the prompts and if the menu asks if you wish to repair your version of Windows, select that option. It may work depending on how corrupt the system is. You may have to let Windows re format and start again.
2answers
Hi experts ! I have Windows7 professional
Here is the page link for driver download for Windows 7 of your notebook.
Download "Driver - Keyboard, Mouse and Input Devices"
and installed.It will solve your problem.
Webcam not wrokin , shows a code 10 error
in add/remove uninstall cam then unplug it from pc in device manager uninstall driver then restart and run software do not plug cam in until prompted or after restart
let me know
Mine hp laptop.. before loading windows xp it will reboote.
Well if you can install new XP then format the whole system and install the frest copy of XP again(recommended only if data into the system is not important for you)
2answers
Installation problem
Replace the hard drive with a new one. IT takes a standard IDE 2.6" laptop drive - I would try newegg.com they have pretty good prices probably about $100 for a 120gb drive.
The hard drive is under the 3x4" cover on the bottomn of the machine.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
