Question about Korg Music
How to save my prorgram in my korg x5d keyboard
3 Suggested Answers
6ya staff
SOURCE:
guitarmanjoe
Joe Patch
  • 336 Answers
SOURCE: where can i buy to korg x5d main board
Check the output socket for corrosion, this would stop the sound from getting to the amp. Plug in an output cable and wiggle it around to see if it works intermittently. Plug it in and out a few times and see. We are looking for a dirty connection.
Posted on Mar 03, 2013
Richard Brooks
  • 242 Answers
SOURCE: what is the difference between a korg x5 and a korg x5d ?
Need to know what device is....I can't guess...some just mean Delay or Dynamic.....
Posted on Dec 03, 2014
When i star or on my korg x5d the display are just like cherismas light it does not finishe inistalation and logo of korg x5d then it will be empity lignht scren
How to Initialize (reset), and preload on the Korg X5/X5D/DR Initialization: Hold Page + and Page - while turning it on.
Preload: Global Screen 5A, then select "OK".
ROM Check: Hold Edit and Global/Multi while turning it on.
Apr 17, 2016 | Korg Music
How can we off the touch of korg X5D keyboard?
If you mean is to OFF the key touch,this is the steps :
  • Press GLOBAL.
  • Press PAGE+ . Find menu VELOCITY CURVE. To select parameter,use left/right arrow buttons(move cursor).
  • Set the value to 0,by press up/YES or down/NO buttons, or use VALUE slider.
Jul 05, 2015 | Korg Music
How to save x5d sounds in laptop
if you do not already use a midi sequencing software try "Bome's SendFX". After installing, go to X5D menu 04A MIDI DUMP, choose data you want do dump (e.g. "all"). Make sure, that no SYSEX FIlter is active while working with a sequencing software.
After transmission, you can save the "yoursounds.mid" file and send it back to the X5D later.
Apr 19, 2014 | Korg X5d
Korg x5d some keys not sounding
The contacts are probably dirty or bent. The keyboard is relatively easy to remove if you have any experience.
Apr 08, 2014 | Korg Music
Where can i buy to korg x5d main board
Feb 28, 2013 | Music
Hello my Korg X5D on switching on shows 00:Initcombi0 on top display and "battery low" blinks on lower display, Keys from 33-40 are malfunctioning ( giving odd sound) other keys are working...
There's a watch type battery (flat disc) on one of the boards inside the X5D. This maintains the settings while the keyboard is switched off and could be the whole problem.
The keys are on two different circuit boards connected with a multi-pin cable. If the cable were dislodged I would expect it to simply cut off half the keys but it's probably worth checking.
Oct 30, 2011 | Korg X5d
My korg x5 keyboard only turns on but nothing comes out of the display.nothing is loaded and no characters displayed.
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
Feb 18, 2011 | Korg X5d
Hi. My Korg X5d shows a sequence of small squares in the display panel and will not boot. Can you help?
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
Nov 18, 2010 | Korg X5d
Keyboard seems to be stuck in key of D How do I get it back to C ?
On page 105 of your X5D manual, read up about "transpose". Setting the transpose shifts the notes plus or minus from the normal.
If you don't have a manual, you can download one for free.
Nov 13, 2010 | Korg X5d
Music Logo
Top Korg Music Experts
Michial Gueffroy
Poul Brinchs Larsen
Joseph Wright
Are you a Korg Music Expert? Answer questions, earn points and help others
