Televison & Video Logo
matt martin Posted on Sep 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SANSUI TV/VCR COMBO. WILL WORK ON DC CAR BATTERY. DOES NOT WORK ON HOUSE CURRENT. 110 IS REACHING THE BOARD. FUSES ARE GOOD.
Franco Dosil
Level 3:
Top Expert:
  • Sansui Master 10,542 Answers
  • Posted on Sep 19, 2019
Franco Dosil
Sansui Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
378950
Points
178965
Hi Matt, for what you say the internal power supply of the Combo Sansui, 110 volts a12v, is not working
Indicate model of Combo Sansui, which you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Matt, por lo que comentas no esta funcionando la fuente de alimentacion interna del Combo Sansui, de 110 volts a12v
Indica modelo del Combo Sansui, del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Testimonial: "Unit is like new, made aug 2002. Model COM091B. WORKS WELL IN CAR. WILL POWER UP ON HOUSE CURRENT. FUSES GOOD POWER AT RAW FEED GOOD. CAPACITORS SEEM TO BE FINE."
  • matt martin
    matt martin Oct 14, 2019
    SORRY...........WILL NOT POWER UP ON HOUSE CURRENT.
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Jun 04, 2007
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Anonymous
  • 790 Answers
  • Posted on Oct 12, 2007
SOURCE: 13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
A
Anonymous
  • Posted on Nov 13, 2007
SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
thanks
Bob Citizen
  • 520 Answers
  • Posted on May 13, 2008
SOURCE: "DEW" is on screen and VCR not working
When the DEW appears leave tv on for several hrs at room temp. The heat from the picture tube will help remove the moisture.
A
Anonymous
  • Posted on Jun 21, 2008
SOURCE: TV code for Emerson EWC 1301 TV/VCR Combo
how do use revmote to program tv vhs thank you11
Does anyone know if there is a fuse for the 12 volt system in these ac/dc models. Mine came on for a second and then stopped when I attempted to use the cigarette lighter function, yet will still work on...
Yes! there is a fuse located inside the set on the main board, make sure your the set is unplugged before you remove the back cover, next follow the 12volt line cord to the main circuit board, there should be a small gma glass fuse right where the wire is. Check the polarity of the 12volt cord to make sure it will work.
1helpful
Vrdvd4005, remote quit, changed batteries,
I would almost stake my life that the inferred diode is the problem, this has happend to mine in the past I replaced the diode and it has worked for years now.
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
1helpful
Tv runs on 110 but not 12volt
There is a fuse on the DC power line for AC/DC sets and you can start by making sure it isn't blown. The fuse may be in the cigarette lighter plug itself, or inside the TV. If you find the fuse blown, replace it with one of the same value and try it again. The fuses sometimes do go for no good reason. If there is some internal trouble with the TV, the fuse will go again and you'll know for sure.
1helpful
Is this set digital ready?
I'm sorry, but this tv is not digital. You might be able to use an inverter that converts 12volts DC to 120volts AC to power a digital converter box.
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Need to find a code to work the tv/vcr combo from a comcast digital remote
Try the codes for Orion, Emerson and RCA as well as Sansui. Good Luck!
20helpful
4answers
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
2helpful
2answers
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
