HP PSC 2410 All-In-One InkJet Printer Logo
Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get my scanner to work it says try starting scan from put
HP Photosmart Premium how do I scan????
  • BLANA Sep 14, 2009
    But my printer/scanner is wireless.
elig1000
Level 2:
  • Expert 112 Answers
  • Posted on Sep 14, 2009
elig1000
Expert
Level 2:
Answers
112
Questions
0
Helped
45073
Points
257
First you have to load the scanner (twain driver). Then load the scanning software. Then plug the printer/scanner into the usb port on the pc. The pc should then recognize the scanner. You might have to turn your pc off then on again to recognize the scanner. Then try to open the scanning software on your pc and put the document on the scanning glass and press the aquire/scan button on the software. Hopefully, that should work.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Installed my Hp Photosmart printer c309a to a Toshiba (Windows 7) I am able to print wirelessly. But when i try to scan -"to computer" the screen on the printer reads !! Scan Problem-try...
Please install and run the below mentioned software to automatically diagnose and fix scanning issue:
HP Scan Diagnostic Utility
After installing this utility,
  1. Press the Power button to turn on the product, if it is not already on.
  2. From the Scanner column in the Scan Diagnostic Utility, select your HP product.
  3. Click Diagnose . The Scan Diagnostic Utility diagnoses various scanning problems, and then displays a list of results. The results display either when the tool detects an error, or when the tool completes the diagnosis and there are no errors.
    If this utility doesn't solve your issue, please revert back.
1helpful
I have an HP photosmart premium fax C309 series. It is connected to a mac but the scanner function will not work. It gives a preview and then says an unknown error occurred. I tried uninstalling and...
Hello
Based on information you have provided I understand that you have problems with your Printer. I realize the inconvenience it may have caused you. I will provide my best information to get a fix for this issue.
As per my analysis,
Issue : Mac OS : Scanning with HP Scan Software
Printer : HP Photosmart Premium Fax All-in-One - C309a
OS: MAC
The solution for the issue you described is provided in the online HP knowledge-base article Link :
I Cannot Scan on MAC
Setting up and using the Product
Scan Does not start
Thank you,
Cheers
Tejodhar Atreya U
13helpful
HP Printer - Scanning Documents
i had the same problem with vista home premium. vista does not support one touch scanning (pressing the scan button on the printer). to use scanner with vista home os use the paint application and start scanning with the file section. step by step:
start (windows) icon lower left tool bar
programs
accessories
paint
file
from scanner or camera
the hp should start working - note: i sent a short cut to the desk top for the paint program for future use
1helpful
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
2helpful
2answers
Scanning documents from hp photosmart c4180, on hp tx1030 with vista 32 premium
trying to scan pic from phto to pc and only gives me options of scan and reprint or scan to memory card all i want to do is put a phto on my pc?
3helpful
7answers
k24674
Grand Canyon Tech
Grand Canyon Tech
